(DP32) Forum Icons
DawPi
  • 1 miesiąc temu...
<if test="$this->settings['hoverDescriptions']='no'"></if>
<if test="$this->settings['removeStatsColumn']='no'"></if>
<if test="$this->settings['customForumIcons']='no'"></if>
{parse js_module="board"}
{parse variable="sidebar_enabled" default="$show_side_blocks"}
<if test="boardIndexTop:|:true"></if>
<div id='board_index' class='ipsLayout <if test="sideBarEnabledL:|:$this->templateVars['sidebar_enabled']">ipsLayout_withright</if> ipsLayout_largeright clearfix <if test="sidebarclosed:|:IPSCookie::get('hide_sidebar') == '1'">no_sidebar</if>'>
    <div id='categories' class='ipsLayout_content clearfix'>
    <!-- CATS AND FORUMS -->
        <if test="cats_forums:|:is_array( $cat_data ) AND count( $cat_data )">
            <foreach loop="categories:$cat_data as $_data">
                <if test="cat_has_forums:|:is_array( $_data['forum_data'] ) AND count( $_data['forum_data'] )">
                    <div id='category_{$_data['cat_data']['id']}' class='category_block block_wrap'>
                        {parse replacement="header_start"}<h3 class='maintitle'>
                            <a class='toggle right' href='#' title="{parse expression="sprintf( $this->lang->words['toggle_cat'], IPSText::striptags( IPSText::htmlspecialchars($_data['cat_data']['name'] ) ) )"}">{parse expression="sprintf( $this->lang->words['toggle_cat'], $_data['cat_data']['name'] )"}</a> <a href="{parse url="showforum={$_data['cat_data']['id']}" seotitle="{$_data['cat_data']['name_seo']}" template="showforum" base="public"}" title='{parse expression="sprintf( $this->lang->words['view_cat'], IPSText::striptags( IPSText::htmlspecialchars($_data['cat_data']['name'] ) ) )"}'>{$_data['cat_data']['name']}</a>
                        </h3>{parse replacement="header_end"}
                        <div class='ipsBox table_wrap removeDefault'>
                            <div class='ipsBox_container'>
                                <table class='ipb_table' summary="{$this->lang->words['forums_in_cat']} '{$_data['cat_data']['name']}'">
                                    <tr class='header hide'>
                                        <th scope='col' class='col_c_icon'>&nbsp;</th>
                                        <th scope='col' class='col_c_forum'>{$this->lang->words['cat_name']}</th>
                                        <if test="$this->settings['removeStatsColumn']=='no'"><th scope='col' class='col_c_stats stats'>{$this->lang->words['stats']}</th></if>
                                        <if test="canSeeLastInfoHeader:|:$this->memberData['gbw_view_last_info']"><th scope='col' class='col_c_post'>{$this->lang->words['last_post_info']}</th></if>
                                    </tr>
                                    <!-- / CAT HEADER -->
                                    <foreach loop="forums:$_data['forum_data'] as $forum_id => $forum_data">
                                        <if test="forumRedirect:|:$forum_data['redirect_on']">
                                            <tr class='redirect_forum' id='f_{$forum_data['id']}'>
                                                <td class='col_c_icon'>
                                                    <if test="hasUnread:|:$forum_data['_has_unread']">
                                                        <a id='forum_img_{$forum_data['id']}' href="{parse url="app=forums&module=forums&section=markasread&marktype=forum&forumid={$forum_data['id']}&returntoforumid={$this->request['f']}&i=1" base="public"}" data-tooltip="{$this->lang->words['bi_markread']}" class='forum_marker'><if test="$forum_data['icon'] != '' AND $forum_data['icon'] !='0'">{$forum_data['icon']}<else /><img src='{$this->settings['img_url']}/f_icon.png' /></if></a>
                                                    <else />
                                                        <if test="$forum_data['icon'] != '' AND $forum_data['icon'] !='0'">{$forum_data['icon']}<else /><img src='{$this->settings['img_url']}/f_icon_read.png' /></if>
                                                </td>
                                                <td <if test="$this->settings['removeStatsColumn']=='no'"><if test="canSeeLastInfoRedirect:|:$this->memberData['gbw_view_last_info']">colspan='2'</if></if> class='col_c_forum'>
                                                    <h4 class='forum_name'><strong class='highlight_unread'><a href="{parse url="showforum={$forum_data['id']}" seotitle="{$forum_data['name_seo']}" template="showforum" base="public"}" title='{parse expression="IPSText::striptags( IPSText::htmlspecialchars( $forum_data['name'] ) )"}'>{$forum_data['name']}</a></strong></h4>
                                                    <if test="$forum_data['description']"><if test="$this->settings['hoverDescriptions']=='yes'"><span class='forum_desc_pos'><span class='forum_desc_con'><span class='forum_description'>{$forum_data['description']}</span></span></span><else /><p class='desc forum_desc'>{$forum_data['description']}</p></if></if>
                                                </td>
                                                <td class='desc'>
                                                    <ul class='last_post ipsType_small'>
        <li class='desc lighter'><em>{parse format_number="$forum_data['redirect_hits']"} {$this->lang->words['rd_hits']}</em></li>
        </ul>
                                                </td>
                                            </tr>
                                        <else />
                                            <tr class='<if test="hasUnreadClass:|:$forum_data['_has_unread']">unread<else />notnew</if>'>
                                                        <a id='forum_img_{$forum_data['id']}' href="{parse url="app=forums&amp;module=forums&amp;section=markasread&amp;marktype=forum&amp;forumid={$forum_data['id']}&amp;returntoforumid={$this->request['f']}&amp;i=1" base="public"}" data-tooltip="{$this->lang->words['bi_markread']}" class='forum_marker'>
                                                        <if test="$this->settings['customForumIcons']=='yes'">
                                                            <php>
        $imageURL = "{$this->settings['img_url']}";
        $imageFolder = basename($imageURL);
        $forumId = $forum_data['id'];
                                                            </php>
                                                            <if test="is_file( DOC_IPS_ROOT_PATH . '/' . PUBLIC_DIRECTORY . '/style_images/' . $imageFolder . '/forum_images/' . $forumId . '.png' )">
        <img src="{style_images_url}/forum_images/{$forum_data['id']}.png" alt="" />
                                                            <else />
        <img src="{style_images_url}/forum_images/default.png" alt="" />
                                                        <else />
                                                        </a>
                                                    <else />
                                                            <php>
                                                            </php>
        <img src="{style_images_url}/forum_images/{$forum_data['id']}.png" alt="" <if test="$this->memberData['member_id']">class='fadedForumIcon'</if> />
                                                            <else />
        <img src="{style_images_url}/forum_images/default.png" alt="" <if test="$this->memberData['member_id']">class='fadedForumIcon'</if> />
                                                        <else />
                                                </td>
                                                <td class='col_c_forum'>
                                                        <if test="hasQueuedAndCanSeeIcon:|:!empty($forum_data['_has_queued_and_can_see_icon'])">
                                                            <a href='{parse url="showforum={$forum_data['id']}&amp;modfilter=unapproved" seotitle="{$forum_data['name_seo']}" template="showforum" base="public"}' title='{$this->lang->words['view_unapproved']}' class='ipsBadge ipsBadge_orange' data-tooltip="{parse expression="sprintf( $this->lang->words['f_queued'], $forum_data['queued_topics'], $forum_data['queued_posts'])"}" style='vertical-align: top'>{$this->lang->words['f_queued_badge']}</a>
                                                        <strong class='highlight_unread'><a href="{parse url="showforum={$forum_data['id']}" seotitle="{$forum_data['name_seo']}" template="showforum" base="public"}" title='{parse expression="IPSText::striptags( IPSText::htmlspecialchars( $forum_data['name'] ) )"}'>{$forum_data['name']}</a></strong> <if test="$this->settings['customForumIcons']=='yes'"><if test="$forum_data['_has_unread']"><span class='ipsBadge ipsBadge_orange' style='vertical-align: top; margin-left: 5px;'>NEW</span></if></if>
                                                    </h4>
<if test="$this->settings['removeStatsColumn']=='yes'"><div class='forum_stats'><span>{$this->lang->words['topics']}:</span> {$forum_data['topics']}  &nbsp; <span>{$this->lang->words['replies']}:</span> {$forum_data['posts']}</div></if>
                                                    <if test="showSubForums:|:$forum_data['show_subforums'] AND count( $forum_data['subforums'] ) AND $forum_data['show_subforums']">
                                                        <ol class='ipsList_inline ipsType_small subforums' id='subforums_{$forum_data['id']}'>
                                                            <foreach loop="subforums:$forum_data['subforums'] as $__id => $__data">
        <if test="showSubForumsLit:|:$__data[3]"><li class='unread'><else /><li></if>
        <a href="{parse url="showforum={$__data[0]}" seotitle="{$__data[2]}" template="showforum" base="public"}" title='{parse expression="IPSText::striptags( IPSText::htmlspecialchars($__data[1]) )"}'>{$__data[1]}</a>
        </li>
                                                            </foreach>
                                                        </ol>
                                                </td>
                                                <if test="$this->settings['removeStatsColumn']=='no'"><td class='col_c_stats ipsType_small'>
                                                    <ul>
                                                        <li>{$forum_data['topics']} {$this->lang->words['topics']}</li>
                                                        <li>{$forum_data['posts']} {$this->lang->words['replies']}</li>
                                                    </ul>
                                                </td></if>
                                                <if test="canSeeLastInfo:|:$this->memberData['gbw_view_last_info']">
                                                <td class='col_c_post'>
                                                    <if test="hideLastInfo:|:$forum_data['hide_last_info']">
                                                        <ul class='last_post'>
                                                            <li class='desc lighter'><em>{$this->lang->words['f_protected']}</em></li>
                                                        </ul>
                                                    <else />
<if test="hideTopicInTitle:|:$forum_data['_hide_last_date']">
                                                        {parse template="userSmallPhoto" group="global" params="array('member_id' => $forum_data['last_poster_id'], 'members_seo_name' => $forum_data['seo_last_name'], 'pp_small_photo' => $forum_data['pp_small_photo'], 'alt' => '' )"}
                                                        <else />
                                                        {parse template="userSmallPhoto" group="global" params="array('member_id' => $forum_data['last_poster_id'], 'members_seo_name' => $forum_data['seo_last_name'], 'pp_small_photo' => $forum_data['pp_small_photo'], 'alt' => sprintf( $this->lang->words['bindex_userphoto_alt'], $forum_data['last_title'], $forum_data['members_display_name'] ) )"}
                                                            <if test="!$forum_data['last_id']">
        <li class='desc lighter'><em>{$this->lang->words['f_none']}</em></li>
                                                            <else />
        <li>
        <span class='highlight_unread'>{$forum_data['last_topic_title']}</span>
        </li>
        <li>
        <span class='desc lighter blend_links'>
        <if test="hideDateUrl:|:$forum_data['_hide_last_date']">
        {parse date="$forum_data['last_post']" format="DATE"}
        <else />
        <a href='{parse url="showtopic={$forum_data['last_id']}&amp;view=getlastpost" base="public" template="showtopic" seotitle="{$forum_data['seo_last_title']}"}' title='{$this->lang->words['view_last_post']}'>{parse date="$forum_data['last_post']" format="DATE"}</a>
        </if></span>
        <if test="lastPosterID:|:$forum_data['last_poster_id']">
        {$this->lang->words['by']} {parse template="userHoverCard" group="global" params="$forum_data"}
        </li>
                                                        </ul>
                                                </td></if>
                                            </tr>
                                    </foreach>
                                </table>
                        </div>{parse replacement="box_end"}
                        <br />
            </foreach>
    <if test="sideBarEnabled2:|:$this->templateVars['sidebar_enabled']">
        <div id='index_stats' class='ipsLayout_right clearfix' <if test="sidebarclosed2:|:IPSCookie::get('hide_sidebar') == '1'">style='display: none'</if>>
            <foreach loop="side_blocks:$side_blocks as $block">
                {$block}
            </foreach>
        <a href='#' id='toggle_sidebar' title='{$this->lang->words['toggle_sidebar']}' data-closed="{$this->lang->words['_laquo']}" data-open="&times;">&nbsp;</a>
//<![CDATA[
    var markerURL  = ipb.vars['base_url'] + "app=forums&module=ajax&section=markasread&i=1"; // Ajax URL so don't use &amp;
    var unreadIcon = "<img src='{$this->settings['img_url']}/f_icon_read.png' />";
    <if test="markercatforums:|:is_array( $cat_data ) AND count( $cat_data )">
        <foreach loop="markercategories:$cat_data as $_data">
            <if test="markerhasforums:|:is_array( $_data['forum_data'] ) AND count( $_data['forum_data'] )">
                <foreach loop="markerforums:$_data['forum_data'] as $forum_id => $forum_data">
                    <if test="markernotredirect:|:!$forum_data['redirect_on']">
                        <if test="markerhasunread:|:$forum_data['_has_unread']">
    ipb.global.registerMarker( "forum_img_{$forum_data['id']}", "{$forum_data['img_new_post']}", markerURL + "&forumid={$forum_data['id']}" );
                </foreach>
        </foreach>
</script>
<if test="showTotals:|:$this->settings['show_totals']">
    <div id='board_stats'>
        <ul class='ipsType_small ipsList_inline'>
            <li class='clear'>
                <span class='value'>{$stats['info']['total_posts']}</span>
                {$this->lang->words['total_posts']}
            </li>
            <li class='clear'>
                <span class='value'>{$stats['info']['mem_count']}</span>
                {$this->lang->words['total_members']}
            </li>
            <li class='clear'>
                {IPSMember::makeProfileLink( $stats['info']['last_mem_name'], $stats['info']['last_mem_id'], $stats['info']['last_mem_seo'], 'value' )}
                {$this->lang->words['newest_member']}
            </li>
            <li class='clear' data-tooltip="{$stats['info']['most_time']}">
                <span class='value'>{$stats['info']['most_online']}</span>
                {$this->lang->words['online_at_once']}
            </li>
        </ul>
<div id='board_statistics' class='statistics clearfix'>
    <h4 class='statistics_head clearfix'><ul id='stat_links' class='ipsList_inline right ipsType_small'>
        <if test="statsLinks:|:1==1"> <!-- Hook point -->
            <li><a href="{parse url="app=forums&amp;module=extras&amp;section=stats&amp;do=leaders" base="public"}" title="{$this->lang->words['sm_forum_leaders_title']}">{$this->lang->words['sm_forum_leaders']}</a></li>
            <li><a href="{parse url="app=forums&amp;module=extras&amp;section=stats" base="public"}" title="{$this->lang->words['sm_all_posters_title']}">{$this->lang->words['sm_today_posters']}</a></li>
            <li><a href="{parse url="app=members&amp;module=list&amp;max_results=20&amp;sort_key=posts&amp;sort_order=desc&amp;filter=ALL" base="public" seotitle="false"}" title="{$this->lang->words['sm_overall_posters_title']}">{$this->lang->words['sm_overall_posters']}</a></li>
            <if test="reputationEnabled:|:$this->settings['reputation_enabled']">
                <li>
                    <a href="{parse url="app=members&amp;module=reputation&amp;section=most" base="public" template="most_liked" seotitle="most_liked"}">
                        <if test="reputationType:|:$this->settings['reputation_point_types'] == 'like'">
                            {$this->lang->words['most_rep_likes']}
                        <else />
                            {$this->lang->words['most_rep_rep']}
                    </a>
                </li>
    </ul>
<if test="showActive:|:$this->settings['show_active'] && $this->memberData['gbw_view_online_lists']">{parse expression="sprintf( $this->lang->words['online_right_now'], $stats['TOTAL'] )"} {$this->lang->words['active_users']}</if></h4>
    <if test="$this->settings['show_active']"><p class='statistics_brief desc'>
        {parse expression="sprintf( $this->lang->words['active_users_detail'], $stats['MEMBERS'], $stats['GUESTS'], $stats['ANON'] )"}
        <if test="onlineListEnabled:|:$this->settings['allow_online_list']">&nbsp;&nbsp;<a href='{parse url="app=members&amp;module=online&amp;sort_order=desc" base="public"}'>({$this->lang->words['online_link']})</a> </if>
    </p></if>
    <if test="activeNames:|:count($stats['NAMES']) && $this->settings['show_active']">
        <br />
        <p>
            <span class='name'>{parse expression="implode( ",</span> <span class='name'>", $stats['NAMES'] )"}</span>
        </p>
Edytowane przez Piotr Marian Krzysztof
