(DP33) Customize Posts
Zobacz plik
With this modification you can allow your members to set default look of their posts. Their can set: font size, font height, text align and many more!
Features:
  • enable/disable mod,
  • select which groups can use this mod,
  • check or not secondary groups also,
  • block any text property, - select color select type: colorpicker or dropdown list,
  • set your own font styles.
