Witam posiadam problem z skryptami JS gdyż oby dwa nie chcą razem funkcjonować
Skrypt nr 1
<script type="text/javascript" src="./admin/applications_addon/other/panel/sources/js/jquery-1.3.2.min.js"></script>
	<script type="text/javascript" src="./admin/applications_addon/other/panel/sources/js/fancybox/jquery.mousewheel-3.0.4.pack.js"></script>
	<script type="text/javascript" src="./admin/applications_addon/other/panel/sources/js/fancybox/jquery.fancybox-1.3.4.pack.js"></script>
	<link rel="stylesheet" type="text/css" href="./admin/applications_addon/other/panel/sources/js/fancybox/jquery.fancybox-1.3.4.css" media="screen" />
	var jqs= jQuery.noConflict();
		jqs(document).ready(function() {
			jqs("a#obrazek").fancybox({
			/*	\'overlayShow\'	: false,
				\'transitionIn\'	: \'elastic\',
				\'transitionOut\'	: \'elastic\'*/
				\'transitionIn\'	:\'none\',
				\'transitionOut\'	: \'none\'
	</script>
Skrypt nr 2
		<script  src="http://code.jquery.com/jquery-latest.min.js"></script>
		<script type="text/javascript" src="./admin/applications_addon/other/panel/sources/js/noty/jquery.noty.js"></script>
		<script  type="text/javascript" src="./admin/applications_addon/other/panel/sources/js/noty/layouts/bottom.js"></script>
		<script  type="text/javascript" src="./admin/applications_addon/other/panel/sources/js/noty/layouts/bottomCenter.js"></script>
		<script  type="text/javascript" src="./admin/applications_addon/other/panel/sources/js/noty/layouts/bottomLeft.js"></script>
		<script  type="text/javascript" src="./admin/applications_addon/other/panel/sources/js/noty/layouts/bottomRight.js"></script>
		<script  type="text/javascript" src="./admin/applications_addon/other/panel/sources/js/noty/layouts/center.js"></script>
		<script  type="text/javascript" src="./admin/applications_addon/other/panel/sources/js/noty/layouts/centerLeft.js"></script>
		<script  type="text/javascript" src="./admin/applications_addon/other/panel/sources/js/noty/layouts/centerRight.js"></script>
		<script  type="text/javascript" src="./admin/applications_addon/other/panel/sources/js/noty/layouts/inline.js"></script>
		<script  type="text/javascript" src="./admin/applications_addon/other/panel/sources/js/noty/layouts/top.js"></script>
		<script  type="text/javascript" src="./admin/applications_addon/other/panel/sources/js/noty/layouts/topCenter.js"></script>
		<script  type="text/javascript" src="./admin/applications_addon/other/panel/sources/js/noty/layouts/topLeft.js"></script>
		<script  type="text/javascript" src="./admin/applications_addon/other/panel/sources/js/noty/layouts/topRight.js"></script>
		<script  type="text/javascript" src="./admin/applications_addon/other/panel/sources/js/noty/themes/default.js"></script>';
		<script type=\"text/javascript\">
			jQuery(document).ready(function() {
				   var n = noty({
					text: '$info',
					type: '$type',
					layout: '$position',
					closeWith: ['click'],
					timeout: $close
		</script>
Każdy z skryptów z osobna działa poprawnie
Skrypt nr 1 jest od wyświetlania obrazków a drugi od powiadomień
forum.omegaelite.pl - forum miłośników opla omegi.
