Problem z PM i shoutboxem
Prosze nie zamykajcie tego tylko pomozcie, bo juz sam nie wiem co robic, szukalem odpowiedzi na forum, ale nie udalo mi sie znalezc. Jest to moje pierwsze spotkanie z ipb, zainstalowalem sobie ipb 2.1.3, postawilem to na lycosie(tymczasowo{polecili byscie cos lepszego?-co?}), wszystko jest ok, do poki nie wstawie shoutboxa, wywala blad w class_display.php, niby robie wszystko tak jak jest w instrukcji, ale jak wlaczam shoutbox, to moge zapomniec o wysylaniu PM, prosze pomozcie, oto fragment class_display gdzie powinien byc wklejony(i jest) kod shoutboxa:
$this->ipsclass->skin['_wrapper'] = str_replace( "<% COPYRIGHT %>" , $copyright , $this->ipsclass->skin['_wrapper']);
$this->ipsclass->skin['_wrapper'] = str_replace( "<% BOARD HEADER %>" , $this_header , $this->ipsclass->skin['_wrapper']);
$this->ipsclass->skin['_wrapper'] = str_replace( "<% BOARD FOOTER %>" , $this_footer , $this->ipsclass->skin['_wrapper']);
$this->ipsclass->skin['_wrapper'] = str_replace( "<% NAVIGATION %>" , $nav , $this->ipsclass->skin['_wrapper']);
$this->ipsclass->skin['_wrapper'] = str_replace( "<% SKINCHOOSER %>" , $skin_jump , $this->ipsclass->skin['_wrapper']);
$this->ipsclass->skin['_wrapper'] = str_replace( "<% LANGCHOOSER %>" , $lang_jump , $this->ipsclass->skin['_wrapper']);
$this->ipsclass->skin['_wrapper'] = str_replace( "<% QUICKSTATS %>" , $quickstats , $this->ipsclass->skin['_wrapper']);
$this->ipsclass->skin['_wrapper'] = str_replace( "<% LOFIVERSION %>" , $this->_get_lofi_link() , $this->ipsclass->skin['_wrapper']);
$this->ipsclass->skin['_wrapper'] = str_replace( "<% SYNDICATION %>" , $this->_get_synd_link() , $this->ipsclass->skin['_wrapper']);
$this->ipsclass->skin['_wrapper'] = str_replace( "<% CHARSET %>" , $this->ipsclass->vars['gb_char_set'], $this->ipsclass->skin['_wrapper']);
// D21-Shoutbox
if ($this->ipsclass->sbox->settings['showglobal'] == 1)
require_once(ROOT_PATH.'sources/action_public/D2mods/Shoutbox/classes/class.misc.php');
$this->miscfuncs = new miscfuncs;
$this->miscfuncs->reg_class(&$this);
require_once(ROOT_PATH.'sources/action_public/D2mods/Shoutbox/classes/class.shout.php');
$sbf = new shoutfuncs();
$sbf->no_regclass(&$this);
if ($this->ipsclass->sbox->settings['globaltype'] == 0 && strtolower($this->ipsclass->input['act']) == 'idx')
$this->ipsclass->skin['_wrapper'] = str_replace("<!--D2-SHOUTBOX-->", $sbf->global_sbox(), $this->ipsclass->skin['_wrapper']);
else if ($this->ipsclass->sbox->settings['globaltype'] == 1)
to jest linia 338 }
if ( empty($output_array['OVERRIDE']) )
$this->ipsclass->skin['_wrapper'] = str_replace( "<% MEMBER BAR %>", $output_array['MEMBER_BAR'], $this->ipsclass->skin['_wrapper']);
else
$this->ipsclass->skin['_wrapper'] = str_replace( "<% MEMBER BAR %>", $this->ipsclass->compiled_templates['skin_global']->member_bar_disabled(), $this->ipsclass->skin['_wrapper']);
// Do we have a PM show?
if ( $this->ipsclass->member['show_popup'] AND ! $this->ipsclass->member['members_disable_pm'] )
$this->ipsclass->DB->simple_construct( array( 'update' => 'members', 'set' => 'show_popup=0', 'where' => 'id='.$this->ipsclass->member['id'] ) );
$this->ipsclass->DB->simple_shutdown_exec();
if ( $this->ipsclass->input['act'] != 'Msg' )
$this->ipsclass->skin['_wrapper'] = str_replace( '<!--IBF.NEWPMBOX-->', $this->ipsclass->get_new_pm_notification(), $this->ipsclass->skin['_wrapper'] );
bardzo prosze o pomoc i z gory dzieki
Jaki błąd ?...skopiuj jego treść...
taki, jak chce wyslac PM
Fatal error: Allowed memory size of 8388608 bytes exhausted at (null):0 (tried to allocate 54145 bytes) in /data/members/free/tripod/uk/l/u/k/lukasek101/htdocs/forum/sources/classes/class_display.php on line 338
czy moze byc to wina serwera, ze czegos nie obsluguje?
to wina serwera, zmineisz go i będzie ok, błąd mówi że za mało pamięci jest
