Problem z dodawaniem/edycją for...
Witajcie!
Kiedy prubuje cokolwiek zrobić w konfiguracji for wyskakuje mi następujący błąd:
mySQL query error: INSERT INTO inv2_forums (name,description,use_ibc,use_html,status,password,sort_key,sort_order,prune,top
icfilter,preview_posts,allow_poll,allow_pollbump,forum_allow_rating,inc_postcount
,parent_id,sub_can_post,quick_reply,redirect_on,redirect_hits,redirect_url,redire
ct_loc,notify_modq_emails,permission_showtopic,permission_custom_error,id,positio
n,topics,posts,last_post,last_poster_id,last_poster_name,permission_array) VALUES('Minimal2's strefa','',1,0,1,'','last_post','Z-A',100,'',0,1,0,0,1,-1,0,1,0,'','','','',0,'',2,2,0,0,'','','','a:5:{s:11:\\\"start_perms\\\";s:3:\\\"3,4\\\";s:11:\\\"reply_perms\\\";s:3:\\\"3,4\\\";s:10:\\\"read_perms\\\";s:1:\\\"*\\\";s:12:\\\"upload_perms\\\";s:3:\\\"3,4\\\";s:10:\\\"show_perms\\\";s:1:\\\"*\\\";}')
SQL error: Unknown column 'topicfilter' in 'field list'
SQL error code:
Date: Monday 23rd 2006f January 2006 04:08:12 PM
Bardzo proszę o pomoc...
brakuje ci kolumny w tabeli wiec ja dodaj
jaka powinna byc ta kolumna masz w najnowszej instalce ipb w katalogu install/sql/ jest plik ze schematami tabel
czy to ten kod:
CREATE TABLE inv2_forums (
 id smallint(5) NOT NULL default '0',
 topics mediumint(6) default NULL,
 posts mediumint(6) default NULL,
 last_post int(10) default NULL,
 last_poster_id mediumint(8) NOT NULL default '0',
 last_poster_name varchar(32) default NULL,
 name varchar(128) NOT NULL default '',
 description text,
 position tinyint(2) default NULL,
 use_ibc tinyint(1) default NULL,
 use_html tinyint(1) default NULL,
 status tinyint(1) default '1',
 password varchar(32) default NULL,
 last_title varchar(128) default NULL,
 last_id int(10) default NULL,
 sort_key varchar(32) default NULL,
 sort_order varchar(32) default NULL,
 prune tinyint(3) default NULL,
 show_rules tinyint(1) default NULL,
 preview_posts tinyint(1) default NULL,
 allow_poll tinyint(1) NOT NULL default '1',
 allow_pollbump tinyint(1) NOT NULL default '0',
 inc_postcount tinyint(1) NOT NULL default '1',
 skin_id int(10) default NULL,
 parent_id mediumint(5) default '-1',
 quick_reply tinyint(1) default '0',
 redirect_url varchar(250) default '',
 redirect_on tinyint(1) NOT NULL default '0',
 redirect_hits int(10) NOT NULL default '0',
 redirect_loc varchar(250) default '',
 rules_title varchar(255) NOT NULL default '',
 rules_text text NOT NULL,
 topic_mm_id varchar(250) NOT NULL default '',
 notify_modq_emails text,
 sub_can_post tinyint(1) default '1',
 permission_custom_error text NOT NULL,
 permission_array mediumtext NOT NULL,
 permission_showtopic tinyint(1) NOT NULL default '0',
 queued_topics mediumint(6) NOT NULL default '0',
 queued_posts mediumint(6) NOT NULL default '0',
 forum_allow_rating tinyint(1) NOT NULL default '0',
 forum_last_deletion int(10) NOT NULL default '0',
 PRIMARY KEY  (id),
 KEY position (position,parent_id)
Jak wklejam to do okna wykonania zapytania do bazy do wyskakuje błąd 1064 :D coś, że jest zła składnia... aha i dodam, że prefix mam ten sam.
Co robie źle ?
/edit:
#1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'position( position, parent_id )  )' at line 44
aha i w kodzie zaznacza mi na czerwono POSITION
cóż dodałem pole "topicfilder" po polu "prune" i poszło...
Tylko niewiem czy dobrze, bo zrobiłem je typu WAR/CHAN i max 40 znaków
Pozdr...
