[community.invisionpower.com - pliki] Maximum Posts/Threads Limit in Certain Forum for 24 Hours
This hook will enable you to set a maximum number of posts/threads in certain forums for a 24 hours period. By default it is set to 5 posts/threads limit. This is ideal if you for example have a forum/s where the discussion/s can get a bit out of hand and you want the groups to cool off.
Anyway, after you install the MaxPosts.xml file through Manage Hooks in your Admin Panel, you can configure it at the System Settings. There you will see a new setting called NenaDice. Click on it and configure the hook to your needs. There you can enable/disable the hook, set the maximum number of posts/threads that you want to limit for 24 hours, choose the forum/s where you want to enforce it, enter your own custom error message and as last but not least you can choose which groups can bypass the limit.
Non Refundable.
Pobierz plik
