Witam oto mam taki problem gdy odpowiadam na jakiekolwiek tematy :
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(/home/knyf/domains/cs-piwko.com/public_html/uploads) is not within the allowed path(s): (/home/dawidek492:/tmp:/var/tmp:/usr/local/php5:/usr/local/php53:/usr/local/php54:/var/www/html) in /home/xxx/domains/cs-piwko.pl/public_html/admin/applications/core/sources/classes/attach/class_attach.php on line 1565
Warning: Cannot modify header information - headers already sent by (output started at /home/dawidek492/domains/cs-piwko.pl/public_html/admin/applications/core/sources/classes/attach/class_attach.php:1565) in/home/xxx/domains/cs-piwko.pl/public_html/ips_kernel/classAjax.php on line 323
Warning: Cannot modify header information - headers already sent by (output started at /home/dawidek492/domains/cs-piwko.pl/public_html/admin/applications/core/sources/classes/attach/class_attach.php:1565) in/home/xxx/domains/cs-piwko.pl/public_html/ips_kernel/classAjax.php on line 326
Warning: Cannot modify header information - headers already sent by (output started at /home/dawidek492/domains/cs-piwko.pl/public_html/admin/applications/core/sources/classes/attach/class_attach.php:1565) in/home/xxx/domains/cs-piwko.pl/public_html/ips_kernel/classAjax.php on line 327
Warning: Cannot modify header information - headers already sent by (output started at /home/dawidek492/domains/cs-piwko.pl/public_html/admin/applications/core/sources/classes/attach/class_attach.php:1565) in/home/xxx/domains/cs-piwko.pl/public_html/ips_kernel/classAjax.php on line 328
{"success":"1","post":"\n\n
\n\t\t<\/a>\n\t\t\n\t\n\t\t\n\t\t
\n\t\t\t\n\t\t\t\t
Podpowiecie mi co jest błędem i jak to naprawić.
Jak zły dział proszę o przeniesienie.
Przepraszam za podbijanie postów ale podaje wszystkie podpowiedzi by ułatwić wam pomoc.
Dodatkowo w pliku class_attach.php
/* Check dir exists... */
if( ! file_exists( $this->upload_path ) )
if( @mkdir( $this->upload_path, IPS_FOLDER_PERMISSION ) )
@file_put_contents( $this->upload_path . '/index.html', '' );
@chmod( $this->upload_path, IPS_FOLDER_PERMISSION );
else
$this->error = "no_upload_dir";
return false;
else if( ! is_writeable( $this->upload_path ) )
$this->error = "no_upload_dir_perms";
return false;
