[long]
 Date: Thu, 23 May 2013 18:16:38 +0000
 Error: 1146 - Table 'foxik25_forum.ipbcore_sys_login' doesn't exist
 IP Address: 31.42.15.1 - /admin/index.php?adsess=fba655d76682db066c3d0b93969c12dc&app=forums&module=forums&section=forums&do=forums_overview
 mySQL query error: SELECT m.*,g.*,s.* FROM ipbmembers m  LEFT JOIN ipbgroups g ON ( m.member_group_id=g.g_id )
 LEFT JOIN ipbcore_sys_login s ON ( s.sys_login_id = m.member_id )   WHERE member_id=631
 | admin/sources/base/ipsRegistry.php                                         | [adminSessions].__construct                                                   | 3812              |
 | admin/sources/base/ipsRegistry.php                                         | [ips_MemberRegistry].init                                                     | 3681              |
 | admin/sources/base/ipsRegistry.php                                         | [ips_MemberRegistry].instance                                                 | 605               |
 Date: Thu, 23 May 2013 18:16:42 +0000
 Date: Thu, 23 May 2013 18:16:45 +0000
 Date: Thu, 23 May 2013 18:28:45 +0000
 IP Address: 83.5.209.11 - /admin/index.php
 mySQL query error: SELECT sys_login_id, sys_cookie FROM ipbcore_sys_login WHERE sys_login_id=0
 | admin/sources/classes/output/adminOutput.php                               | [adminFunctions].staffGetCookie                                               | 156               |
 | admin/sources/classes/class_admin_functions.php                            | [adminOutput].initTabKeys                                                     | 88                |
 | admin/sources/base/ipsRegistry.php                                         | [adminFunctions].postOutputInit                                               | 630               |
 Date: Thu, 23 May 2013 18:28:49 +0000
 Date: Thu, 23 May 2013 18:28:59 +0000
 Date: Thu, 23 May 2013 18:31:55 +0000
 Date: Thu, 23 May 2013 18:31:56 +0000
 Date: Thu, 23 May 2013 18:32:06 +0000
 Date: Thu, 23 May 2013 18:32:38 +0000
 Error: 1146 - Table 'foxik25_forum.ipbmembers_warn_logs' doesn't exist
 IP Address: 217.212.231.83 - /index.php?/topic/1217-skojarzenia/
 mySQL query error: SELECT p.*,m.member_id as mid,m.name,m.member_group_id,m.email,m.joined,m.posts, m.last_visit, m.last_activity,m.login_anonymous,m.title as member_title, m.warn_level, m.warn_lastwarn, m.members_display_name, m.members_seo_name, m.member_banned, m.has_gallery, m.has_blog, m.members_bitoptions,m.mgroup_others,pp.*,w.wl_id,pc.*,rep_index.rep_rating as has_given_rep,rep_cache.rep_points, rep_cache.rep_like_cache,cca.*,ccb.cache_content as cache_content_sig, ccb.cache_updated as cache_updated_sig FROM ( SELECT pid FROM ipbposts WHERE topic_id=1217 AND  queued=0  ORDER BY pid asc LIMIT 0,20 ) z  LEFT JOIN ipbposts p ON ( p.pid=z.pid )
 LEFT JOIN ipbmembers m ON ( m.member_id=p.author_id )
 LEFT JOIN ipbprofile_portal pp ON ( m.member_id=pp.pp_member_id )
 LEFT JOIN ipbmembers_warn_logs w ON ( w.wl_content_app='forums' and w.wl_content_id1=p.pid )
 LEFT JOIN ipbpfields_content pc ON ( pc.member_id=p.author_id )
 LEFT JOIN ipbreputation_index rep_index ON ( rep_index.app='forums' AND
						             rep_index.type='pid' AND
						             rep_index.type_id=p.pid AND
						             rep_index.member_id=1289 )
 LEFT JOIN ipbreputation_cache rep_cache ON ( rep_cache.app='forums' AND rep_cache.type='pid' AND rep_cache.type_id=p.pid )
 LEFT JOIN ipbcontent_cache_posts cca ON ( cca.cache_content_id=p.pid )
 LEFT JOIN ipbcontent_cache_sigs ccb ON ( ccb.cache_content_id=m.member_id )   ORDER BY z.pid asc
 | admin/applications/forums/modules_public/forums/topics.php                 | [public_forums_forums_topics]._getPosts                                       | 211               |
 | admin/sources/base/ipsController.php                                       | [public_forums_forums_topics].doExecute                                       | 306               |
 Date: Thu, 23 May 2013 18:32:42 +0000
 Date: Thu, 23 May 2013 18:32:49 +0000
 Date: Thu, 23 May 2013 18:36:49 +0000
 Date: Thu, 23 May 2013 18:42:54 +0000
 Date: Thu, 23 May 2013 18:44:52 +0000
 Date: Thu, 23 May 2013 18:44:53 +0000
 Date: Thu, 23 May 2013 18:45:00 +0000
 Date: Thu, 23 May 2013 18:45:05 +0000
 Date: Thu, 23 May 2013 18:45:07 +0000
 Date: Thu, 23 May 2013 18:46:12 +0000
 Error: 1045 - Access denied for user 'foxik25_23'@'localhost' (using password: TAK)
 Date: Thu, 23 May 2013 18:46:26 +0000
 IP Address: 91.228.92.94 - /
 Date: Thu, 23 May 2013 18:46:41 +0000
 Date: Thu, 23 May 2013 18:46:59 +0000
 Date: Thu, 23 May 2013 18:47:09 +0000
 Date: Thu, 23 May 2013 18:47:13 +0000
 Date: Thu, 23 May 2013 18:47:19 +0000
 Date: Thu, 23 May 2013 18:48:46 +0000
 IP Address: 89.228.26.6 - /
 Date: Thu, 23 May 2013 18:49:31 +0000
 IP Address: 142.0.129.105 - /index.php?app=forums&module=post&section=post&do=new_post&f=4+Result:+chosen+nickname+%22Tupenanda%22;+registered;+logged+in;+nofollow+is+found;+success+-+posted+to+%22Regulaminy%22;+BB-code+not+working;
 Date: Thu, 23 May 2013 18:49:33 +0000
 Date: Thu, 23 May 2013 18:49:34 +0000
 Date: Thu, 23 May 2013 18:50:21 +0000
 IP Address: 83.29.10.96 - /
 Date: Thu, 23 May 2013 18:52:49 +0000
 Date: Thu, 23 May 2013 18:52:51 +0000
 Date: Thu, 23 May 2013 18:52:55 +0000
 Date: Thu, 23 May 2013 18:53:33 +0000
 Date: Thu, 23 May 2013 18:54:07 +0000
 Date: Thu, 23 May 2013 18:58:19 +0000
 Date: Thu, 23 May 2013 18:58:30 +0000
 Date: Thu, 23 May 2013 18:58:32 +0000
 Date: Thu, 23 May 2013 19:09:53 +0000
 Date: Thu, 23 May 2013 19:09:56 +0000
 Date: Thu, 23 May 2013 19:22:31 +0000
 Error: 1146 - Table 'foxik25_forum.ipbtask_logs' doesn't exist
 IP Address: 83.5.209.11 - /index.php?app=core&module=task
 mySQL query error: INSERT INTO ipbtask_logs (`log_title`,`log_date`,`log_ip`,`log_desc`) VALUES('RSS Import Update',1369336951,'83.5.209.11','Zakończono import RSS (0)')
 | admin/sources/classes/class_taskmanager.php                                | [db_main_mysql].insert                                                        | 515               |
 | admin/applications/forums/tasks/rssimport.php                              | [class_taskmanager].appendTaskLog                                             | 159               |
 | admin/sources/classes/class_taskmanager.php                                | [task_item].runTask                                                           | 208               |
 |        | [class_taskmanager].runTask                                                   |                   |
 Date: Thu, 23 May 2013 19:22:49 +0000
 Date: Thu, 23 May 2013 19:26:16 +0000
 Date: Thu, 23 May 2013 19:26:18 +0000
 Date: Thu, 23 May 2013 19:26:19 +0000
 Date: Thu, 23 May 2013 19:26:27 +0000
 Date: Thu, 23 May 2013 19:26:29 +0000
 Date: Thu, 23 May 2013 19:31:15 +0000
 IP Address: 91.222.116.24 - /index.php?/topic/1085-stworzenie-klanu-na-serverze/
 mySQL query error: SELECT p.*,m.member_id as mid,m.name,m.member_group_id,m.email,m.joined,m.posts, m.last_visit, m.last_activity,m.login_anonymous,m.title as member_title, m.warn_level, m.warn_lastwarn, m.members_display_name, m.members_seo_name, m.member_banned, m.has_gallery, m.has_blog, m.members_bitoptions,m.mgroup_others,pp.*,w.wl_id,pc.*,rep_index.rep_rating as has_given_rep,rep_cache.rep_points, rep_cache.rep_like_cache,cca.*,ccb.cache_content as cache_content_sig, ccb.cache_updated as cache_updated_sig FROM ( SELECT pid FROM ipbposts WHERE topic_id=1085 AND  queued=0  ORDER BY pid asc LIMIT 0,20 ) z  LEFT JOIN ipbposts p ON ( p.pid=z.pid )
						             rep_index.member_id=1262 )
 Date: Thu, 23 May 2013 19:31:37 +0000
 IP Address: 193.106.78.165 - /admin/index.php
 Date: Thu, 23 May 2013 19:31:49 +0000
 IP Address: 91.197.15.34 - /admin/index.php
 Date: Thu, 23 May 2013 19:32:05 +0000
 IP Address: 83.22.91.180 - /admin/index.php
 Date: Thu, 23 May 2013 19:32:20 +0000
 Date: Thu, 23 May 2013 19:32:21 +0000
 Date: Thu, 23 May 2013 19:32:22 +0000
 Date: Thu, 23 May 2013 19:32:23 +0000
 Date: Thu, 23 May 2013 19:32:24 +0000
 Date: Thu, 23 May 2013 19:32:25 +0000
 Date: Thu, 23 May 2013 19:32:26 +0000
 Date: Thu, 23 May 2013 19:32:27 +0000
 Date: Thu, 23 May 2013 19:32:28 +0000
 Date: Thu, 23 May 2013 19:32:41 +0000
 Date: Thu, 23 May 2013 19:32:46 +0000
 IP Address: 87.205.210.199 - /admin/index.php
 Date: Thu, 23 May 2013 19:32:53 +0000
 Date: Thu, 23 May 2013 19:32:54 +0000
 Date: Thu, 23 May 2013 19:32:55 +0000
 Date: Thu, 23 May 2013 19:33:07 +0000
 IP Address: 91.204.154.4 - /index.php?s=8087bec06b6f998a6b6e3b1d71d18c37&app=core&module=task
 mySQL query error: INSERT INTO ipbtask_logs (`log_title`,`log_date`,`log_ip`,`log_desc`) VALUES('Tweet Importer',1369337587,'91.204.154.4','Import z Twittera wyłączony. Zadanie wyłączone.')
 | admin/applications_addon/other/shoutbox/tasks/shoutbox_tweet.php           | [class_taskmanager].appendTaskLog                                             | 83                |
 Date: Thu, 23 May 2013 19:33:10 +0000
 IP Address: 91.204.154.4 - /index.php?app=core&module=task
 mySQL query error: INSERT INTO ipbtask_logs (`log_title`,`log_date`,`log_ip`,`log_desc`) VALUES('Archiver',1369337590,'91.204.154.4','0 pozycji zarchiwizowanych')
 | admin/applications/core/tasks/archive.php                                  | [class_taskmanager].appendTaskLog                                             | 94                |
[/long] Edytowane przez Macsch15
Musisz przywrócić tabelę core_sys_login.
CREATE TABLE ipbcore_sys_login (
  sys_login_id int(8) NOT NULL default 0,
  sys_cookie mediumtext,
  sys_bookmarks MEDIUMTEXT,
  PRIMARY KEY  (sys_login_id)
