Problem z logowaniem przez Steama
Przejdź do rozwiązania Rozwiązane przez insp,
Updrading:
Step 1 (Skip to Step 2 if you are upgrading from 1.0.4):
First upload the files in the upload folder to your forum directory
Step 2:
Go to your ACP and Click Manage Hooks. Browse for and import the supplied 'Steam_Login.xml' hook.
Step 3:
There is no step 3, your done
Tak, wykonałem wszystkie te kroki wyżej podane.
To w końcu to aktualizowałeś (vide wklejony fragment) czy instalowałeś?
Installation:
Step 1:
Step 2:
Go to your ACP and click Log In Management. Look at the bottom and install Steam login method by clicking the + Icon to it's side.
Step 3:
Enable the Steam Authentication Method by clicking the red Disabled text on the right of it
Step 4:
Step 5:
Enjoy your day as all should be well!
