Split Posted December 2, 2024 Posted December 2, 2024 Better Stats Pro Zobacz plik Better Stats Pro is an advanced application that integrates the functionality of two built-in widgets: "Member Statistics" and "Forum Statistics", creating one comprehensive widget. It is an extended version of my free plugin "Better Statistics". In this version, users can sort/add/remove tiles according to their preferences. Tiles list: - Total posts [Forums app required] - Total topics [Forums app required] - Total members - Most online - Newest member - Total reactions - Total bans - Site exits - Space - Total files [Downloads app required] - Total downloads files [Downloads app required] - Total views files [Downloads app required] - Total images [Gallery app required] - Total images comments [Gallery app required] - Total albums [Gallery app required] - Total blogs - Total blog entries - Total pages comments - Total pages views Dodający Split Dodano 02.12.2024 Kategoria Płatne modyfikacje 5 Wspierana wersja 5.0.x 1
Bosss Posted March 7, 2025 Posted March 7, 2025 @Split Please some help You can see - what i mean regards Bosss
Split Posted March 8, 2025 Author Posted March 8, 2025 14 godzin temu, Bosss napisał(a): @Split Please some help You can see - what i mean regards Bosss Hi. Forum address?
Bosss Posted March 8, 2025 Posted March 8, 2025 11 minutes ago, Split said: Hi. Forum address? https://www.oldlibar.com/
Split Posted March 8, 2025 Author Posted March 8, 2025 This is not a problem with the plugin, but with your template.
Bosss Posted March 8, 2025 Posted March 8, 2025 8 minutes ago, Split said: This is not a problem with the plugin, but with your template. Get code from Ehren /* Center widget titles */ .ipsWidget__header > :first-child{ flex-grow: 1; text-align: center; } but when change - left - same
Split Posted March 8, 2025 Author Posted March 8, 2025 In such cases, you should contact the template author, not here. But wait. .ipsBox__header, .ipsWidget__header, .ipsInnerBox__header { justify-content: start; }
Bosss Posted March 8, 2025 Posted March 8, 2025 6 minutes ago, Split said: In such cases, you should contact the template author, not here. But wait. .ipsBox__header, .ipsWidget__header, .ipsInnerBox__header { justify-content: start; } I moved this code /* Center widget titles */ .ipsWidget__header > :first-child{ flex-grow: 1; text-align: center; } and put this .ipsBox__header, .ipsWidget__header, .ipsInnerBox__header { padding: 1em 1.2em; display: flex; flex-direction: row; flex-wrap: wrap; align-content: center; justify-content: left; align-items: center; gap: 1em; border-radius: calc(var(--i-box--bo-ra) - var(--i-box--bo-wi)) calc(var(--i-box--bo-ra) - var(--i-box--bo-wi)) 0 0; border-bottom: 1px solid var(--i-background_4); font-size: 1.4em; font-weight: 600; } changed only - justify-content: left
Bosss Posted March 8, 2025 Posted March 8, 2025 16 minutes ago, Split said: In such cases, you should contact the template author, not here. But wait. .ipsBox__header, .ipsWidget__header, .ipsInnerBox__header { justify-content: start; } works fine - thanks 😀👍
Chester_Benno Posted May 22, 2025 Posted May 22, 2025 @Split: Would you please consider adding support for other applications, such as Pages, Downloads, Gallery etc? For example: Pages: Content Views, Article Comments, Article Entries, Latest Submission.
Split Posted May 23, 2025 Author Posted May 23, 2025 7 godzin temu, Chester_Benno napisał(a): @Split: Would you please consider adding support for other applications, such as Pages, Downloads, Gallery etc? For example: Pages: Content Views, Article Comments, Article Entries, Latest Submission. Hi. I will add it in the next version next week. 1
Chester_Benno Posted May 23, 2025 Posted May 23, 2025 Thank you, split. Awesome resource, I really like the modern take with the second theme.
Chester_Benno Posted June 13, 2025 Posted June 13, 2025 On 5/23/2025 at 4:46 AM, Split said: Hi. I will add it in the next version next week. Did you manage to find time to add the suggestions, @Split? I am sure you are plenty busy, and I don't mean to push, but I am curious.
Split Posted June 13, 2025 Author Posted June 13, 2025 5 godzin temu, Chester_Benno napisał(a): Did you manage to find time to add the suggestions, @Split? I am sure you are plenty busy, and I don't mean to push, but I am curious. Hi. The update should be out tonight or in the morning. I've already done it but I'm testing to make sure there are no errors and that it calculates correctly. 1
Chester_Benno Posted June 16, 2025 Posted June 16, 2025 Thanks for the update. 👏 Can Pages be added, please? 🙏🏻 Total Entries Total Comments Total Views Total Reactions Latest Submission I'll PM you, as I used to have a plugin for 4.7 which did this. If it was included in your app, it would be awesome.
qnkov Posted June 16, 2025 Posted June 16, 2025 Can we have Today Views (to show uniques visits of people), Yesterday views too. 1
qnkov Posted September 1, 2025 Posted September 1, 2025 @Split when we can expect update for the mention suggestions ?
Split Posted September 5, 2025 Author Posted September 5, 2025 W dniu 1.09.2025 o 23:13, qnkov napisał(a): @Split when we can expect update for the mention suggestions ? It should be added in the next update. 1
qnkov Posted September 5, 2025 Posted September 5, 2025 23 minutes ago, Split said: It should be added in the next update. Waiting for it. When you gonna update?
qnkov Posted September 23, 2025 Posted September 23, 2025 On 9/5/2025 at 7:14 PM, Split said: 1 or 2 week. 2 weeks passed, any update?
Chester_Benno Posted March 7 Posted March 7 @Split Please upload 1.2.0 here https://codeity.eu/file/11-better-stats-pro/
Chester_Benno Posted March 16 Posted March 16 @Split I keep getting this. Quote Locked Task: ClearViews One of the routine maintenance tasks which run in the background has failed several times, which may indicate a configuration issue. Application Better Stats Pro Task ClearViews Last Run Never You should check the logs for any indication of the issue or attempt to run it manually. If the task does not run successfully you should contact the author of the application for further assistance.
Split Posted March 17 Author Posted March 17 6 godzin temu, Chester_Benno napisał(a): @Split I keep getting this. A fix will be released within 24 hours. Thank you for reporting this. 1
Recommended Posts
Create an account
Register a new accountSign in
Sign In Now
