[community.invisionpower.com - pliki] MUDD2 Multi Useraccount Detection Dinger
MUDD - Multiple Useraccount Detection Dinger v. 2.0.0 BETA 1
(Yes, I did work hard to make the acronym fit)
MUDD is an alarm system to catch members using multiple profiles from the same computer. When a user is detected using multiple accounts, a report in the report centre is created. It will bust a good chunk of the people but remember no system is foolproof and every approach has its downsides.
Additional Features:
  • Easily whitelist computers and users from the applications admin area
  • Whitelist users and computers from the report centre
  • You can set certain members to use a debug mode which can help you diagnose missed trips
Please Note:
  • This app is in BETA so there are more than likely going to be a few issues
  • There are additional methods of catching duplicates that I am working on implementing but can't promise when those will be out
  • This app is NOT compatible with earlier versions of MUDD. If you have the old MUDD 1.x hooks installed, get rid of them
  • This app was developed for IPB 3.1.1 - don't think it will work on earlier versions.
To install:
  • Upload the contents of the UPLOAD_INTO_FORM_ROOT folder into your forums folder. Be sure to keep the folder structure intact.
  • Browse to your admin->System->Manage Applications & Modules page
  • Scroll down to the bottom and click the Install link for MUDD
Once installed:
  • Configure via the My Apps->MUDD->Settings page
  • You can tweak who can view the reports via the MUDD report plugin (admin->System->Report Centre->Plugin Manager-> Edit Mudd Settings)
To Debug:
  • Browse to MUDD settings page ( My Apps->MUDD->Settings )
  • In the Debug Member IDs - enter a comma separated list of members who will see the debug box
  • An annoying white box will appear at the top of each of these users screens giving some info that can help track down missed trips.
Stuff to do:
  • Increasing detection methods
  • Sort out trip notifications
  • Have a cold beer
I look forward to comments, suggestions and small sacrifices of Oreo shakes in my honour.
nJoy
Pobierz plik
