[community.invisionpower.com - pliki] Number of Posts to Vote in Polls
I took the idea from this topic:
http://community.inv...e__pid__2032600
This will give the admin the option to make it so only users with a certain post count set by him/her can vote in polls. By default it is set to 5 posts.
Install the hook.xml file through Manage Hooks in your Admin Panel and then to congigure it go to System Settings. There you will see a new setting called NenaDice. Click on it and configure the hook to your needs. There you can enable/disable the hook, set the number of posts needed to vote in polls, enter your custom error message and as last but not least you can choose which groups and forums can bypass the post restriction.
Pobierz plik
