Problem z instalacją Universal Mod Installer v2.6
Wgrywam na serwer katalog mod_install i source nadaje cmod 755 katalogowi mod_install i 644 dwóm plikom w tym katlaogu index.html i ipd_components.xml następnie wchodzę w zakładkę components ale nie mam tu zadnego zarządzania komponentami czy miejsca na za załadowanie pliku .xml:(
tu nie chodzi o tego moda....i bez niego powinno być w zakładce odpowiednie okienko do załadowania .xml a u mnie jest pusto.
# Upload - Upload the contents of the /mod_install and /sources directories to your forum's root directory, being sure to keep the directory structure intact. This should put a file called index.html in your forum's /mod_install directory, and a file called umi.php in your forum's /sources/components_acp directory.
# Delete - Check and see if you have a file named index.php, or a folder called /images in your forum's /mod_install directory. These could be left over from previous versions of this script. If either of these exist on your site, delete them. In addition, any XML and PHP files in this /mod_install directory from a previous IPB version can be safely deleted as well.
# CHMOD - Ensure that the CHMOD on your /mod_install folder is set to 755. Any files contained in this folders can be CHMOD 644.
# Install - Log in to your board's Admin CP, and on the Admin tab, click the Components -> Manage Components menu link. At the bottom of this page will be a box labeled 'Import XML Component File'. Use the first option there to browse to the ipd_components.xml file included in this folder and click the Import button.
Dobre ;-)
Wyboldowałem Ci pewne słowa. Tak to jest jak się nie czyta ze zrozumieniem :huh:
