[community.invisionpower.com - pliki] Maximum Characters in Posts/Threads
This hook will set a maximum of characters in posts/topics. By default it iset to 2000 charcters. When users will submit long posts that will exeed 2000 charcters they will get an error message informing them that their post/thread is too long. You can increase or decrease the number of characters to your liking.
Anyway, after you install the MaxChar.xml file through Manage Hooks in your Admin Panel, you can configure it at the System Settings. There you will see a new setting called NenaDice. Click on it and configure the hook to your needs. There you can enable/disable the hook, set the maximum number of charaters in posts/threads, enter your own custom error message and as last but not least you can choose which groups and forums can bypass the maximum characters limit.
Pobierz plik
