Problem po instalacji
sylver
Witam po instalacji IP.Board na stronie głównej wyskoczył mi błąd:
Moje logi to:
Date: Tue, 14 Dec 2010 09:11:58 +0000
Error Number: 1064
Error: Something is wrong in your syntax obok 'AND cache_type IN ('css', 'replacements')' w linii 1
IP Address: *********
Page: /ipb/index.php
Debug: array (
 1 =>
 array (
   'file' => '/home/accounts_s/sylver/public_html/ipb/ips_kernel/classDb.php',
   'line' => 1019,
   'function' => 'query',
   'class' => 'db_driver_mysql',
 3 =>
 array (
   'file' => '/home/accounts_s/sylver/public_html/ipb/admin/sources/base/ipsRegistry.php',
   'line' => 540,
   'function' => '__construct',
   'class' => 'output',
mySQL query error: SELECT * FROM accdskin_cache WHERE cache_set_id= AND cache_type IN ('css', 'replacements')
Date: Tue, 14 Dec 2010 09:12:03 +0000
Error Number: 1064
Debug: array (
 1 =>
 array (
   'line' => 1019,
 3 =>
 array (
   'line' => 540,
Date: Tue, 14 Dec 2010 09:12:10 +0000
Error Number: 1064
Debug: array (
 1 =>
 array (
   'line' => 1019,
 3 =>
 array (
   'line' => 540,
Date: Tue, 14 Dec 2010 09:21:37 +0000
Error Number: 1064
IP Address: *******
Debug: array (
 1 =>
 array (
   'line' => 1019,
 3 =>
 array (
   'line' => 540,
mySQL query error: SELECT * FROM ipb_dcskin_cache WHERE cache_set_id= AND cache_type IN ('css', 'replacements')
Date: Tue, 14 Dec 2010 09:21:41 +0000
Error Number: 1064
Debug: array (
 1 =>
 array (
   'line' => 1019,
 3 =>
 array (
   'line' => 540,
Proszę o pomoc. Pozdrawiam
