[community.invisionpower.com - pliki] Lib rediska for IP.Board
Rediska lib for IP.Board.
Rediska official site: http://rediska.geometria-lab.ru/
Redis official site: http://redis.io/
In archive you can find upload dir, you need to upload all from that dir to forum root.
To use rediska & redis you need install redis on your server & start it.
Then in your applications you can use this code to connect to you redis server.
$dbid = (int) '1'; // you can use something like $this->settings['your_app_setting_key'];$rediskaLib = IPSLib::loadLibrary( IPS_ROOT_PATH . 'sources/classes/rediska.php', 'rediska' );$registry->setClass( 'rediska', new $rediskaLib() );$registry->getClass( 'rediska' )->selectDb( $dbid );
All rediska documentation you can see at http://rediska.geome.../documentation/
Tested on 3.1.2
Pobierz plik
