element pod user_navigation, banner pod secondary_nav
Odnośnie "pod secondary_nav" to dość oczywiste, że kod musi być pod divem odnoszącym się do "secondar_nav" czyli pod tym kodem w Global Template wstawiasz własny kod z reklamą:
<div id='secondary_nav'>
				<ul id='breadcrumb' class='left'>
					<php>$this->did_first = 0;</php>
					<if test="switchnavigation:|:!$this->settings['remove_forums_nav'] OR ipsRegistry::$current_application == 'forums'">
						<li class='first'><a href='{parse url="act=idx" seotitle="false" base="public"}'>{$this->settings['board_name']}</a></li>
						<if test="didfirstnav:|:$this->did_first=1"></if>
					<foreach loop="navigation:$items['navigation'] as $idx => $data">
						<li<if test="notdonefirstapp:|:!$this->did_first"> class='first'</if>><if test="didfirstappnow:|:$this->did_first"><span class='nav_sep'>{parse replacement="f_nav_sep"}</span></if> <if test="navigationlink:|:$data[1]"><a href='{parse url="{$data[1]}" base="$data[4]" seotitle="$data[2]" template="$data[3]"}' title='{$this->lang->words['nav_return_to']}{$data[0]}'></if>{$data[0]}<if test="closenavigationlink:|:$data[1]"></a></if></li>
						<if test="forsuredidfirstnav:|:$this->did_first=1"></if>
					</foreach>
				</ul>
				<ul id='section_links' class='right'>
					<if test="siteruleslink:|:$this->settings['gl_show'] and $this->settings['gl_title']">
					<li><a href='<if test="ruleslink:|:$this->settings['gl_link']">{$this->settings['gl_link']}<else />{parse url="app=forums&module=extras&section=boardrules" base="public"}</if>'><if test="siterulestitle:|:$this->settings['gl_title']">{$this->settings['gl_title']}<else />{$this->lang->words['board_rules']}</if></a></li>
					<li><a href='{parse url="app=core&module=search&do=<if test="ncmember:|:$this->memberData['member_id']">new_posts<else />active</if>&search_app=<if test="viewnewcontentapp:|:$this->registry->getCurrentApplication() != 'core' AND IPSLib::appisSearchable( $this->registry->getCurrentApplication() )">{$this->registry->getCurrentApplication()}<else />forums</if>" base="public"}' accesskey='2'>{$this->lang->words['view_new_posts']}</a></li>
					<li><img src='{$this->settings['img_url']}/feed.png' alt='{$this->lang->words['rss_feed']}' id='rss_feed' class='clickable' /></li>
				</ul>
A odnośnie tego zielonego miejsca to też w GlobalTemplate
znajdź to:
<div id='user_navigation' class='logged_in'>
i NAD to wrzuć sobie to:
<div id='ts3' class='logged_in'> <div id='ts3_info'> TREŚĆ ZIELONEGO MIEJSCA </div> </div>
A w ipb_styles.css to:
#ts3 {
background: #2b4f74;
font-size: 0.8em;
border-width: 2px 2px 2px 2px;
border-style: solid;
border-color: #1c334e;
-moz-border-radius: 6px 6px 6px 6px;
-webkit-border-bottom-left-radius: 6px;
-webkit-border-bottom-right-radius: 6px;
       -webkit-border-top-right-radius: 6px;
       -webkit-border-top-left-radius: 6px;
position: absolute;
top: 200px;
right: 10px;
float: right;
z-index: 9999;
#ts3_info {
	margin-left: 2px;
	margin-right: 2px;
margin-top: 2px;
margin-bottom: 2px;
Pewnie nie wyświetli Ci się idealnie tam gdzie chcesz więc manipulujesz zmiennymi top i right w css. Jednak pamiętaj, że dla zalogowanych i nie zalogowanych położenie będzie musiało być różne, ze wzgledu na różne wymiary okienka tego nad zielonym miejscem. Dlatego potem będziesz musiał sobie dorobić to samo tylko dla nie zalogowanych i wrzucić do if dla nie zalogowanych.
Może coś pomogłem, jak nie to trudno ;p
Edytowane przez Xawier
<if test="$this->memberData['member_id']">
kod dla zalogowanych użytkowników
<else />
kod dla gości
@up nie koniecznie trzeba dodawac kolejny if, w global template już jest if dla nie zalogowanych i zalogowanych.
Więc wystarczy dla zalogowanych kod wrzucic nad:
A dla nie zalogowanych kod wrzucic nad:
<div id='user_navigation' class='not_logged_in'>
A by sobie nie utrudniać życia i możliwe, że user tego nie wie, można skorzystać z kodu podanego wyżej. Jak widać wszystkie drogi prowadzą do ... celu, a autor zrobi, jak mu wygodniej. :-)
