Mam następującą strukturę:
- pliki forum
- index2.php
- SDK
-- Classes
-- IPBSDK.php
-- SDKConfig.php
index2.php:
ob_start();
require_once('SDK/IPBSDK.php');
$sdk = IPBSDK::instance();
$login = $sdk->getClass('login');
$self = $_SERVER['PHP_SELF'];
if( $sdk->request['dologin'] )
$login->authLogin( 'admin', 'test' );
header('Location: ' . $self);
if( $sdk->request['logout'] )
$login->logOut();
if( !$login->isLoggedIn() )
echo "You are not logged in.<Br/>";
echo "Please <a href='{$self}?dologin=1'>Here</a> to login as admin.";
else
echo "Welcome, {$sdk->memberData['members_display_name']} <Br/>";
echo "Please <a href='{$self}?logout=1'>Here</a> to logout.";
SDKConfig.php
* IP.Board 3.0 SDK
* Written by InvisionModding.com Staff Team
* Last Updated: $Date: 2009-07-29 12:00:50 +0300 (Wed, 29 Jul 2009) $
* @author 		$Author: vadimg88 $
* @copyright	(c) 2009 - InvisionModding.com
* @license		http://www.invisionpower.com/community/board/license.html
* @package		Invision Power Board
* @subpackage  IPB SDK
* @link		http://www.InvisionModding.com
* @version		$Rev: 3 $
* Define the fill path to your forums root directory
* Where index.php, initdata.php, conf_global.php files located
* You must put a forward slash at the end of the directory!
* Example: C:/wamp/www/ipb300/
define( 'IPB_FULL_PATH', '/' );
* Define the main IPB SDK directory
* Usually this should be set automatically, But if you see
* All sorts of Warning: require_once(SDKConfig.php) [function.require-once]:
* failed to open stream: No such file or directory in C:\wamp\www\community\SDK\Classes\SDKLoader.php on line 38
* Then enter the path to the SDK directory manually the
* full path including a trailing slash
define('SDK_ROOT_PATH', dirname(__FILE__) . DIRECTORY_SEPARATOR );
require_once('IPBSDK.php');
Cały czas uzyskuje błąd: You must define the full path to the IPB directory in the SDKConfig.php file.
Jaką podać ścieżkę?
