[community.invisionpower.com - pliki] Elliott Brown's IP.Content Customizations (Navbar and Sidebar)
This mod allows you to add a customized navigation bar and sidebar to your IP.Content site, should you use your forums default IP.Board Theme.
This mod allows you to determine what links you should display in your navigation bar, what name they display as, and what pages to show them as active for your Navigation Bar.
It allows you to use a custom sidebar, with full PHP coding allowed for your convenience. You can treat it just like PHP, without the need for the "<?php" and "?>" tags. All you have to do is throw your code in there, the hook will parse it for you. We give you a sample block in a sidebar, for you to see how to set it up.
You can visit http://www.arteixinc...ar-and-sidebar/ to discuss or ask any questions about this modification.
It is recommended to read the "readme.txt" supplied in the .zip file for installation instructions.
Thanks,
Elliott Brown
Pobierz plik
