IMPORTANT!
Some of the contents of this hook are encoded. Please make sure that your server supports ionCube before purchasing this product!
This product is currently available as a 'Try Before You Buy' in my Timed Trial Products download.
This hook will allow you to pick and choose forums to hide posts from guests and/or members of your community.
Features:
* Select which forums are affected
* Select which groups are affected (and which groups are exempt)
* Select which posts of a topic are hidden (hide first post but not replies, show first post but hide replies)
* Partially hide posts (shows a trimmed version of the post)
* Shows an error message within the posts, letting the guest/member know that they cannot view the contents. For guests, will offer links to register/sign in. For members, will offer a link (if one is available) to upgrade their account.
* Option to always enable for guests
* Option to exempt a member if they have posted in the topic (similar to "Reply to View" below).
* NEW (in testing stage): Removes attachments from hidden posts.
Hook also includes "Reply to View". This functions similar to "Hide Posts", except that requires a member to have posted in a topic in order to view all posts in the topic. Settings are treated separately, so you can select the same or different forums, user groups, etc.
Pobierz plik
