[community.invisionpower.com - pliki] (M31) Contact System
The Contact System is a highly customizable Feedback/Contact form, fully integrated with IP.Board as a zero file and skin edit application. Including sophisticated security features, custom fields and the option to allow attachments.
IMPORTANT: Click here for the IPS Marketplace purchase guide on downloading, installing and getting support for my marketplace products.
Keep up to date with DevFuse mod development and releases.
http://i56.tinypic.com/2ze9ngh.jpg http://i43.tinypic.com/53qo7q.png http://i43.tinypic.com/2r7m3v9.png http://i55.tinypic.com/2lkwa4w.jpg
Contact System v3.1.2 feature list:
  • Template hook overrides the existing contact admin link on error pages to redirect members to contact system instead.
  • Search and filter options for contact logs allow you to quickly manage logs.
  • Optional confirmation email to let members know there message was received.
  • Export all logs in SQL or CSV format and an option to export selected logs to SQL or CSV format.
  • Option to add the attachment system to either the contact logs or topic alerts.
  • Send reply emails within the Contact System.
  • Automated generated rss feed for latest messages.
  • AJAX view message box within the Contact Logs.
  • Optional utilization of the inbuilt IP.Board RTE editor.
  • Contact System now checks against the inbuilt IP.Board ban filter list for banned names and email addresses.
  • Optional custom information box, can be filled with alternative contact information, help and faq info, pre contact rules etc..
  • Newly designed Contact Logs page with multi-delete and search functions.
  • 0 skin edits and 0 file edits required, just upload the required files and run the application installer.
  • Turn the system on/off with one easy setting found in the Admin Control Panel.
  • Help tags to ensure all users of the Contact System understands each field and what must be entered.
  • Optional message logging, log all messages sent to you for future reference.
  • Flood Limit: The flood limit will ensure a user with the same ip trying to flood you with spam will be stopped with an error message.
  • Day Limit: Set how many emails you would like to receive from the same user each day.
  • Group permissions for both who can use the Contact System and who can view and manage the Contact Logs.
  • Three layer security check for each email address - format validation, record check and data response check.
  • One easy application overview enables you to manage all the features, security, group settings and subjects in one place.
Contact Custom Fields:
Allows you to quickly and effortlessly add custom fields to the contact system without the need to edit source code. Supported field types include:
  • Text Input
  • Dropdown Box
  • Multi-Select Dropdown
  • Radio Buttons
  • Check Boxes
  • Text Area
  • Password
Per Subject Alert Options:
Allows you to send out emails or pms to individuals or whole user groups as well as create a topic when ever someone sends you a message, these alert options are managed as per subject (each subject can be setup differently), for example you can create a "feedback and suggestions" subject and set it to create a topic in the staff forum and send all the members in the group "moderators" a pm alert.
  • Create, edit and delete each subject within the Admin Control Panel.
  • Group permissions for each subject, allows you to create special subjects for specific groups.
  • Optional send out an alert via pm system to indivual or whole user groups.
  • Optional send out an alet via email to individual or whole user groups.
  • Optional create topic in selected forum when subject is chosen when sending.
Pobierz plik
