[community.invisionpower.com - pliki] IPContent Blocks Management Block+Hook
This hook and IPContent Block will show your selection of blocks on the board index as hooks. You Can additionally Choose To sort the Blocks by Block Title, Block Key, Block Description, Or Block ID in either Ascending or Desending order. The hook appears on the board index when enabled, the block is coded to be usable in any application.
The Hook Can Be Disabled, and the Settings used For The Block standalone.
Pobierz plik
