[community.invisionpower.com - pliki] Move And Pin/Unpin Own Topics
This application will add 2 extra permissions for groups, to move and/or pin/unpin their own topics.
Installation and Configuration:
To install this application, upload the admin folder inside the Upload folder to the root of your forum folder.
Then go to your Admin Panel->Applications & Modules->Manage Applications & Modules and on the right side where it says: Applications Not Installed you will see a new application added called: Move And Pin/Unpin Own Topics. Click on the install button.
To configure it go to the Members tab then from the drop down list choose Member Groups->Manage Member Groups. Then choose the group and/or the groups that you want to allow to move and/or pin/unpin their topics. Click the edit button and you will see an extra tab added there called: Extra.
Click it and set the values accordingly.
Pobierz plik
