[community.invisionpower.com - pliki] Topics with no Replies Block
Just a very simple block that shows topics with no replies. This is very helpful on my board for making sure everyone gets a response. Customize the look and feel to suit your needs.
Install:
1) Login to your ACP and go to Apps > IP.Content > Blocks
2) Scroll down to the bottom of the screen and look for: Install a new plugin block
3) Click the Choose File button and select this xml file.
4) You can use it by inserting {parse block="noreplies"} into the appropriate pages as needed
Pobierz plik
