[community.invisionpower.com - pliki] IPContent Pages Primary Navigation Management
This hook will Allow You To add pages Links to your primary navigation, both before and after the normal Application tabs.
When on the page, the menu item will be properly "active".
You can choose a sort order, field, and pages for both before and after separately... as well as disabling/enabling each separately.
Pobierz plik
