Odpowiedz z IPS
Hello,
It's a bug.. There's fixes for it at
http://community.invisionpower.com/resources/documentation/index.html/_/knowledge-base/ipcalendar-322-upcoming-events-block-on-board-index-shows-no-forthcoming-events-r642
and
http://community.invisionpower.com/resources/documentation/index.html/_/knowledge-base/ipcalendar-322-upcoming-birthdays-block-can-lead-to-a-calendar-not-displaying-birthdays-r643
If you can provide FTP access, I can apply those, but.. The files are there, you should be able to download and apply them. Then, either manually run the task, or the next time it runs it will update properly.
Jason Hanna
Invision Power Services, Inc.
Problem rozwiązany, wszystko dziala jak trzeba :D
