Mam problem ze stylem.
Pokazuje się w PA następujący komunikat :
Warning: Invalid argument supplied for foreach() in /home/bebek112/domains/pro-gamming.pl/public_html/admin/applications/core/skin_cp/cp_skin_templates.php on line 1993
a gdy wezmę ten styl jako styl główny forum wczytuje się i po chwili jest tylko białe tło.
[long]if ( $data['set_by_skin_gen'] )
$desc = '<span class="desctext">' . $this->lang->words['skin_gen_desc'] . '</span>';
if ( ! empty( $skinGenSessions[ $data['set_id'] ] ) )
$canDelete = false;
$desc .= "<a href='{$this->settings['base_url']}{$this->form_code}&do=cancelVisualEditor&set_id={$data['set_id']}' class='mini_button secondary right ipsCancelEditor'>Cancel Visual Editor</a>";
else
$desc .= "<a href='{$this->settings['base_url']}{$this->form_code}&do=launchVisualEditor&set_id={$data['set_id']}' target='_blank' class='mini_button right'>Launch visual editor</a>";
$children[ $data['set_id'] ] = unserialize( $data['set_child_array'] );
$closeLi = FALSE;
//if ( !is_array( $children[ $data['set_parent_id'] ] ) )
// var_dump( $data['set_parent_id'] );
// exit;
$parents = unserialize( $data['set_parent_array'] );
if( is_array($parents) AND count($parents) )
foreach ( $parents as $pid )
foreach ( $children[ $pid ] as $k => $v )
if ( $v == $data['set_id'] )
unset( $children[ $pid ][ $k ] );
break;
$IPBHTML .= <<<EOF
<li id='set_{$data['set_id']}' class='isDraggable'>
<table class='double_pad' id='sort_{$data['set_id']}'>
<tr class='ipsControlRow'>
<td class='forum_row {$subskin}' width='1%' style='text-align: center'>
<div class='draghandle'> </div>
</td>
<td class='forum_row {$subskin}' style='width: 81%'>
{$data['depthguide']}
<img src='{$this->settings['skin_acp_url']}/images/icons/{$data['_setImg']}' />
<strong><a title='{$data['bit_desc']}' href='{$this->settings['base_url']}module=templates&section=templates&do=list&setID={$data['set_id']}'>{$data['set_name']}</a></strong>
{$desc}
EOF;[/long]
Prosze o pomoc.
Pozdrawiam.
