[community.invisionpower.com - pliki] (DDK33) Board Index Face - IP.Content block
This XML will simply add IP.Content block for (DDK33) Board Index Face hook into your IP.Content blocks library.
After this block will be added you can put following replacement into your IP.Content pages and templates easily:
{parse block="ddk33_bif"}
NOTE: Before adding this block you should have (DDK33) Board Index Face hook installed! You can disable (DDK33) Board Index Face hook to not show that on board index, but anyway - this should take place in your IPB.
Pobierz plik
