Jechałem przez libiconv z iso8859-2 na utf8 i w bazie widze pełno pytajników tam gdzie pl znaki. Na forum same krzaki.
Dodatkowo skrypt błędy wywala:
Warning: array_reverse() [function.array-reverse]: The argument should be an array in /home/forum/www/testowe/admin/applications_addon/other/shoutbox/sources/classes/library.php on line 334
Warning: Invalid argument supplied for foreach() in /home/forum/www/testowe/admin/applications_addon/other/shoutbox/sources/classes/library.php on line 341
Warning: Cannot modify header information - headers already sent by (output started at /home/forum/www/testowe/admin/applications_addon/other/shoutbox/sources/classes/library.php:334) in /home/forum/www/testowe/admin/sources/classes/output/formats/html/htmlOutput.php on line 93
Warning: Cannot modify header information - headers already sent by (output started at /home/forum/www/testowe/admin/applications_addon/other/shoutbox/sources/classes/library.php:334) in /home/forum/www/testowe/admin/sources/classes/output/formats/html/htmlOutput.php on line 96
Warning: Cannot modify header information - headers already sent by (output started at /home/forum/www/testowe/admin/applications_addon/other/shoutbox/sources/classes/library.php:334) in /home/forum/www/testowe/admin/sources/classes/output/formats/html/htmlOutput.php on line 100
Warning: Cannot modify header information - headers already sent by (output started at /home/forum/www/testowe/admin/applications_addon/other/shoutbox/sources/classes/library.php:334) in /home/forum/www/testowe/admin/sources/classes/output/formats/html/htmlOutput.php on line 101
Warning: Cannot modify header information - headers already sent by (output started at /home/forum/www/testowe/admin/applications_addon/other/shoutbox/sources/classes/library.php:334) in /home/forum/www/testowe/admin/sources/classes/output/formats/html/htmlOutput.php on line 102
to pewnie wina shoutboxa, ale baza cała była konwertowana tak samo wiec skąd to sie wzięło
Edytowane przez marcin554
A pisałeś do IPS z pytaniem czy wykonują taką konwersję? Bo przyznam, że jakakolwiek operacja na bazie, co ma kilka GB to już potrzeba niezłej maszynki jeśliby się chciało to robić na localhoście.
