Shoutbox - problem
Nie wiedziałem czy temat tu, czy do działu Shoutboxa.
Shoutbox mam jakiś z neta, pod  nulleda.
Wrzuciłem, włączyłem aplikacje itd. Gdy chce już sobie w zarządzaniu grupą zmienić, że mogę pisać i widzieć SB to po zatwierdzeniu jest coś takiego:
If you are seeing this page, it means there was a problem
communicating with our database. Sometimes this error is temporary and
will go away when you refresh the page. Sometimes the error will need
to be fixed by an administrator before the site will become accessible
again.
Gdy klikne "here" to pokazuje sie:
Błąd systemu
[#1127] Musisz wpisać tytuł grupy.
Wróć
Bo Shoutbox nie jest z tej strony, więc się wahałem.
Logi:
 Date: Wed, 13 Feb 2013 14:31:42 +0000
 Error: 1054 - Unknown column 'g_shoutbox_view' in 'field list'
 IP Address: 31.128.25.1 - /admin/index.php?adsess=b1a0265d4a476c5687c9021b88fd2414&app=members&&module=groups&section=groups&do=doedit&secure_key=3d00b12124caf275298d9d30f974961f
 mySQL query error: UPDATE groups SET g_view_board=1,g_mem_info=1,g_can_add_friends=1,g_use_search=1,g_edit_profile=1,g_use_pm=1,g_pm_perday=0,g_is_supmod=0,g_access_cp=0,g_title='Użytkownik',g_access_offline=0,g_dname_changes=0,g_dname_date=0,prefix='<b>',suffix='</b>',g_hide_from_list=0,g_perm_id=3,g_icon='',g_attach_max=0,g_max_messages=50,g_max_mass_pm=5,g_pm_flood_mins=0,g_search_flood=0,g_promotion='3&',g_photo_max_vars='200:150:150',g_dohtml=0,g_bypass_badwords=0,g_can_msg_attach=0,g_attach_per_post=0,g_rep_max_positive=10,g_rep_max_negative=1,g_signature_limits='0:3:500:200:4:',g_hide_online_list=0,g_displayname_unit=0,g_sig_unit=0,g_max_notifications=0,g_max_bgimg_upload=0,g_bitoptions=27197440,g_other_topics=1,g_post_new_topics=1,g_reply_own_topics=1,g_reply_other_topics=1,g_edit_posts=1,g_edit_cutoff=0,g_delete_own_posts=0,g_open_close_posts=0,g_delete_own_topics=0,g_post_polls=0,g_vote_polls=1,g_append_edit=1,g_avoid_q=0,g_avoid_flood=0,g_post_closed=0,g_edit_topic=1,g_topic_rate_setting=1,g_mod_preview=0,g_mod_post_unit=0,g_ppd_unit=0,g_ppd_limit=0,g_shoutbox_view=1,g_shoutbox_use=1,g_shoutbox_posts_req=0,g_shoutbox_posts_req_display=0,g_shoutbox_bypass_flood=0,g_shoutbox_edit=0,g_shoutbox_delete_own=0,g_shoutbox_view_archive=0 WHERE g_id=3
 | admin/applications/members/modules_admin/groups/groups.php                 | [db_main_mysql].update                                                        | 648               |
 | admin/applications/members/modules_admin/groups/groups.php                 | [admin_members_groups_groups]._saveGroup                                      | 98                |
 | admin/sources/base/ipsController.php                                       | [admin_members_groups_groups].doExecute                                       | 306               |
