This is a simple hook that will add a new notification option for your users when their posts will be edited.<br /><br />After you install the hook, the notification option can be enabled at Profile->My Settings->Notification Options->Forums->Notify me when my posts are edited and save the changes. Now anytime your post is edited you will receive a new notification letting you know about that fact showing who edited your post and the link to the post that was edited.<br /><br />Several screenshots of the hook are attached so it will give you a more detailed idea on how it looks like when being used.
Pobierz plik
