<li><a href='#'>Extra Link</a></li>
<li id="nav_more" data-dropdown="right">
                             <a href="#">NAZWA ZAKŁADKI</a>
<ul>
<li><a href="ODNOŚNIK">TREŚĆ</a></li>
</ul>
                            </li>
</ul>
Mam tak i dodaje mi się do głównej zakładki "Rozwinięcia"
A nie, znajdź i wstaw ten kod o....:
<li id='nav_other_apps' style='display: none'>
                        <a href='#' class='ipbmenu' id='more_apps'>{$this->lang->words['more_apps']} <img src='{$this->settings['img_url']}/useropts_arrow.png' /></a>
                    </li>
TUTAJ
                </ul>
Dobra zakładka dodana a co mam zrobić żeby była wysuwana ??
<div id='primary_nav' class='clearfix'>
                <ul class='ipsList_inline' id='community_app_menu'>
                    <if test="showhomeurl:|:$this->settings['home_url'] AND $this->settings['home_name']">
                        <li id='nav_home' class='left'><a href='{$this->settings['home_url']}' title='{$this->lang->words['homepage_title']}' rel="home">{$this->settings['home_name']}</a></li>
                    <if test="hasCustomPrimaryNavigation:|:!empty($header_items['primary_navigation_menu'])">
                            {$header_items['primary_navigation_menu']}
                        <else />
                    <if test="applicationsloop:|:is_array($header_items['applications']) AND count($header_items['applications'])">
                        <foreach loop="applications:$header_items['applications'] as $data">
                            <if test="showingapp:|:$data['app_show']">
                                {parse variable="appActive" default="" oncondition="$data['app_active']" value="active"}
  <li id='nav_app_{$data['app_dir']}' class="left {parse variable="appActive"}"><a href='{parse url="{$data['app_link']}" seotitle="{$data['app_seotitle']}" template="{$data['app_template']}" base="{$data['app_base']}"}' title='{parse expression="sprintf( $this->lang->words['go_to_prefix'], IPSLib::getAppTitle($data['app_dir']) )"}'>{IPSLib::getAppTitle($data['app_dir'])}</a></li>
                        </foreach>
                    </if></if>
                    <if test="$this->settings['navDropdown']=='yes'">
                    <li class='left'><a href="#" class='ipbmenu' id='primary_extra'>Rozwinięcia<img src='{$this->settings['img_url']}/useropts_arrow.png' /></a></li>
                    <if test="$this->settings['defaultMoreDropdown']=='yes'">
                    </li>
<ul>
</ul>
                            </li>
</ul>
                </ul>
if( $('primary_nav') ){ ipb.global.activateMainMenu(); }
</script>
<ul id='primary_extra_menucontent' class='ipbmenu_content' style='display: none'>
<li><a href='/AMXBans/ban_list.php'>AMXBans</a></li>
</ul>
new ipb.Menu($('primary_extra'),$('primary_extra_menucontent'));
                            </script>
            </div></div>
            <div class='wrapper clear'>
a możesz podać mi ten kod co pokazałem już przerobiony ??
bo ja na serio tego nie łapie
Edytowane przez lid3r8
