[community.invisionpower.com - pliki] (SOS34) Reputation System Tied to Best Answer Feature
This hook will tie reputation system to best answer feature.
How it works:
  • When a user has his post marked as solved, he will receive a positive reputation point/like. On the other hand, one point will be decreased if his post is marked as unsolved.
  • The positive reputation point/like will not be given if the author of the post marked as solved and topic author are the same user
Pobierz plik
