[community.invisionpower.com - pliki] (CJ34) Ad-Blocking Detector Premium
With Ad blocking Detector Premium, You will be able to let members know, that you run ads, and they are vital to running your site. With the premium version, gives several additional options, like hiding content while modal window is being display, disable for groups, detect if no-script or JS has been disabled and hide content, disable cookie for persistent reminders. includes templates and language files to allow easy customization of modal windows and messages that appear.
*note: if you have my free version installed, you should remove it before installing this one.
**note: demo link will only work if you are a guest, and the cookie option is enable to avoid repeated modals from browsing the site.
Pobierz plik
