[community.invisionpower.com - pliki] Two-step Authentication for IPB
I'm happy to announce the immediate availability of the Two-step Authentication for IPB on ipbplug.in and IPS Marketplace.
Two-step authentication adds an extra layer of protection to your account. Whenever you sign in to your website, you will need to enter both your password and also a six-digit one-time security code generated by Google Authenticator on your mobile, or by other similar mobile applications.
We took the time to prepare a video that explains everything about the app:
Feel free to create an account at https://ipbplug.in and try to use this new app.
Compatibility:
The app has been designed and tested for IPB 3.4.6. It's not tested for older versions, but it could be compatible though, especially for IPB 3.4.x
It works with the following Authenticators:
Pricing:
The initial price is $17.5 for 6 months. The subscription can be renewed for $6 for another 6 months if and when you feel that you need to install the future updates and upgrades.
Credits:
We are using PHPGangstas GoogleAuthenticator which is Licensed under the BSD License.
Custom work:
Do you need custom work for your IP.Board? please feel free to contact me.
Pobierz plik
