Witajcie, mam mały problem podczas konwersji postów ze skryptu Mybb 1.4 do IPB 3.0.2.
Log:
Date: Mon, 10 Aug 2009 07:19:32 +0000
Error Number: 1146
Error: Table 'gigad_ipb.ipb_cache_store' doesn't exist
IP Address: 89.231.xxx.xxx
Page: /fipb/
Debug: array (
 1 =>
 array (
   'file' => '/home/gigad/domains/xxx/ips_kernel/classDb.php',
   'line' => 988,
   'function' => 'query',
   'class' => 'db_driver_mysql',
 3 =>
 array (
   'file' => '/home/gigad/domains/xxx/admin/sources/base/ipsRegistry.php',
   'line' => 2389,
   'function' => '_loadCaches',
   'class' => 'ips_CacheRegistry',
 4 =>
 array (
   'line' => 2225,
   'function' => 'init',
 5 =>
 array (
   'line' => 495,
   'function' => 'instance',
mySQL query error: SELECT * FROM ipb_cache_store WHERE cs_key IN ( 'systemvars','login_methods','vnums','app_cache','module_cache','hooks','useragents','useragentgroups','skinsets','outputformats','skin_remap','group_cache','settings','lang_data','banfilters','stats','badwords','bbcode','mediatag','profilefields','rss_output_cache','attachtypes','multimod','moderators','announcements','report_cache','chatting','birthdays','calendar','ranks','reputation_levels' )
Date: Mon, 10 Aug 2009 07:29:04 +0000
Error Number: 1064
Error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1
Page: /fipb/admin/index.php?adsess={mojasesja}&app=convert&app=convert&module=board&section=mybb&do=posts&st=3000&cycle=1500&total=5674
Debug: array (
 1 =>
 array (
   'line' => 988,
 4 =>
 array (
   'file' => NULL,
   'line' => NULL,
   'function' => 'convert_posts',
   'class' => 'admin_convert_board_mybb',
 5 =>
 array (
   'file' => '/home/gigad/domains/xxx/admin/applications_addon/ips/convert/modules_admin/board/mybb.php',
   'line' => 96,
   'function' => 'call_user_func',
   'class' => NULL,
 6 =>
 array (
   'file' => '/home/gigad/domains/xxx/admin/sources/base/ipsController.php',
   'line' => 291,
   'function' => 'doExecute',
mySQL query error: SELECT title FROM ipb_topics WHERE tid=
Próbowałem również konwersję z cyklem co 10 postów - wysypywało się zawsze przed 4000 postem.
Jakieś pomysły?
Edytowane przez Kukis
Witaj,
Domyślam się, że robisz od razu konwersję do wersji 3.x. ;) A to błąd, bo w konwerterach do tej wersji jest błąd z globalnymi tematami. Jak zwał tak zwał. To samo jest przy konwersji z phpBB 3.x. Proponuję zrobić najpierw konwersję do wersji IP.Board 2.3.6, a dopiero potem zrobić aktualizację.
Dlaczego? Dlatego, że konwerter do 3.x nie jest sprawny. :D
Ok, mam.
Zainstalowałem IPB 2.3.6.
Wgrałem konwerter.
Przeszedłem do katalogu converter.
Wybrałem skrypt Mybb 1.0 (mimo że mam 1.4).
Przekonwertowałem wszystko.
I mam krzaczki, w sql są znaki zapytania.
Co nie tak zrobiłem?
Wszędzie mam utf8.
Tak.
Co masz na myśli?
I czy nie ma możliwości konwersji od razu do IPB3? Przecież niedziałającego konwertera by nie wypuszczali...
Hmmm... ciekawe O_o
Jakim cudem na latin2 jest dobrze?
I chyba moje ostatnie pytanie: czemu po wejściu na forum mam komunikat:
You do not have permission to view this board
Skoro mam admina, a logowanie powiodło się?
Nie widzę, co tam nabroiłeś z tym logowaniem - może ustawienia cookies, może..... Nie wróżę z fusów. ;) Przejdź do ACP, bo chyba tam się możesz zalogować i sprawdź.
Odnośnie latin2 - serwer daje ciała.
A jakbym tak zrobił:
- za pomocą konwertera do 3.0 przekonwertował bym wszystko oprócz postów
- za pomocą konwertera do 2.3 przekonwertował bym posty, a następnie bazę upgrade'ować na 3.0
I złączył obie bazy to dobrze by było?
1) Po konwersji użytkowników (2.x) wysypuje się baza użytkowników.
2) Podczas konwersji postów (3.x) następuje zatrzymanie, w wyniku czego nie ma 1/3 postów.
Hmm?
Nie no, coś tam działało, ale pokazywało posty nie od odpowiedniego wątku :]
Nie da się nic zrobić, by mógł przekonwertować MyBB -> IPB 3.0? :>
Ktoś miał identyczny problem: http://forums.invisionpower.com/tracker/issue-16813-mybb-148-%26gt%3B-ipb-30-conversion-error/
Napisz tam, że też masz to może zmienią status tego. ;)
Nie znam MyBB, ale czy są w panelu admina jakieś narzędzia przeliczające, aktualizujące etc.?
Więc wina nie bardzo po mojej stronie.
Ma, jednakże wszystko wykonałem przed konwersjami.
Napisałem.
A jakiś masz pomysł z problemem z logowaniem się po konwersji do 2.3?
No i z tym komunikatem:
Ten komunikat pojawia się tuż po wejściu na forum czy po zalogowaniu? Bo jeśli tuż po wejściu to obstawiam wyłączenie forum dla gości. ;) No, ale nie zmienisz tego jak się nie zalogujesz do ACP.
Mam zaraz po wejściu i po zalogowaniu.
Po zalogowaniu nie mam linka do ACP. Nie mogę zalogować się do ACP.
Na pw zaraz wyślę Ci link.
