Transform your board with the Advanced Multi-tool plugin with nearly 50 settings and more to come
DEMO
Features
Font
  • Change the bodys font with a choice of websafe fonts, google fonts or use a uploaded font
  • Edit the font size
  • Edit the font weight
  • Choose to text-transform your font (Make all words UPPERCASE, lowercase, Or The First Words Of Each Letter Capitalized)
Font-Awesome
  • Add font-awesome icons to the primary navigation bar
  • Add font-awesome icons to the secondary navigation bar
  • Add font-awesome icons to the users bar
  • Add font-awesome icons to the users create bar
  • Each have a section to add custom / 3rd party tabs to the plugin font-awesome features
The font-awesome icons are set for the English language and are set for the IPS apps and core functions if you have 3rd party apps or plugins what add tabs then there is a setting to add them to any of the bars above, The same applies if you are using a different language then English (there is a help section in the plugin with full easy outlined details of how to add your own
Forums & Categories
  • Remove the words forums from the index page
  • Remove the start new topic button on the index page
  • Hide sub categories from the index page
  • Remove the forum category names
  • Show total stats (This will caculate the overall total of topics and posts in each category and place the total amount in the category header)
  • Show forums description (This will show the forums description (if one is set) in the category name section below the name)
  • Hide the toggle buttons on the categories
  • Display stats in the categories (Choose to show either the post count, topic count or both in the categories)
Topics & Posts
  • Remove the reply to button
  • Change the colour of the reply to button
  • Change the font colour of the reply button
  • Change the colour of the text on the reply to button
  • Change the colour of the moderator actions button
  • Change the colour of the text on the moderator actions button
Post Buttons & Badges
  • Hide the multi quote button
  • Make the quote text a badge
  • Choose the colour of the quote badge
  • Choose the colour of the quote badge text
  • Make the edit text a badge
  • Choose the colour of the edit badge
  • Choose the colour of the edit badge text
Member Profiles
  • Change the profile cover photo height
  • Choose to upload a default cover photo for all members
Version Compatibility
  • 4.2 All Features
  • 4.1 Some features may not work but most will
Visit the support topic and give me some ideas to add in my updates if you have any (as I do like a update)
Please note all settings are working 100% on the default theme some settings (very minimal) might not work on custom themes using divisions and elements away from IPS,
If you need help visit the support topic (Coming when approved)
