(DP45) RodoGDPR System
Zobacz plik
With this plugin you may add at least four new checkboxes during guest registration process and in the notifications settings for members.
If any checkbox is required then guest must check it before he will be able to register an account. Also for members this required checkbox won't be available to disable.
These checkboxed would be displayed beetween standard checkboxes "Send me news and updates" and "I agree to the Terms of Use" with a "Check All" option to easily select all fields in one click.
P.s. "RODO" in this plugin name is from Poland. It's our Polish translation of GDPR shortcut.
