RESOLVED: PM Does not work
hello
PM System does not work when i use ajax view it give action failed error and in normal mode give database driver error
also Auto welcome member mod does not work
Date: Fri, 23 Oct 2009 23:58:12 +0000
Error Number: 1054
Error: Unknown column 'map_last_topic_reply' in 'field list'
IP Address: 62.135.106.104
Page: /forums/index.php?&app=members&module=ajax&secure_key=eca77c668a24b08a0e4d3754cd07c9f9&section=messenger&do=PMSend&toMemberID=1
Debug: array (
1 =>
array (
'file' => '/home/egyextr1/public_html/forums/ips_kernel/classDb.php',
'line' => 1093,
'function' => 'query',
'class' => 'db_driver_mysql',
3 =>
array (
'file' => '/home/egyextr1/public_html/forums/admin/applications/members/sources/classes/messaging/messengerFunctions.php',
'line' => 1855,
'function' => 'insert',
'class' => 'db_main_mysql',
4 =>
array (
'file' => '/home/egyextr1/public_html/forums/admin/applications/members/modules_public/ajax/messenger.php',
'line' => 151,
'function' => 'sendNewPersonalTopic',
'class' => 'messengerFunctions',
5 =>
array (
'line' => 71,
'function' => '_PMSend',
'class' => 'public_members_ajax_messenger',
6 =>
array (
'file' => '/home/egyextr1/public_html/forums/admin/sources/base/ipsController.php',
'line' => 410,
'function' => 'doExecute',
7 =>
array (
'line' => 89,
'function' => 'execute',
'class' => 'ipsAjaxCommand',
mySQL query error: INSERT INTO message_topic_user_map (map_user_id,map_topic_id,map_folder_id,map_user_active,map_is_starter,map_has_unread,map_read_time,map_is_system,map_last_topic_reply) VALUES(1,1,'myconvo',1,0,1,0,0,1256342292)
profile_portal
* pp_member_id
* Missing index: pp_status
Click here to fix this table's indexes, or you can run the following queries manually:
* ALTER TABLE profile_portal DROP INDEX pp_status, ADD INDEX pp_status (pp_status( 128 ),pp_status_update)
When i fix it , the error return again although my copy is new and fresh and the database is new also
Also i run it manually and the issue still exsit
Yeah,
one man from IPS ( i don't remember right now who is it ), but he wrote that this error isn't important and board should works fine.
If you haven't any other code this must be another reason to this situation.
Let's think...
Could you run this query and check then:
ALTER TABLE message_topic_user_map ADD map_last_topic_reply INT(10) NOT NULL default '0';
