witam mam problem z tym kodem
oto następujący problem
[/html]","switch_option":"0","menu_option_text":"","menu_content_text":"","single_tag":"0","optional_option":"0","image":""},"sql":{"id":"16","title":"SQL Code","desc":"Allows you to enter formatted/syntax-highlighted SQL code","tag":"sql","useoption":"0","example":"
SELECT p.*, t.* FROM posts p LEFT JOIN topics t ON t.tid=p.topic_id WHERE t.tid=7
","switch_option":"0","menu_option_text":"","menu_content_text":"","single_tag":"0","optional_option":"0","image":""},"xml":{"id":"17","title":"XML Code","desc":"Allows you to enter formatted/syntax-highlighted XML code","tag":"xml","useoption":"0","example":"
\n \n Test\n \n
","switch_option":"0","menu_option_text":"","menu_content_text":"","single_tag":"0","optional_option":"0","image":""},"member":{"id":"31","title":"Member","desc":"Given a member name, a link is automatically generated to the member's profile","tag":"member","useoption":"1","example":" runs this site.","switch_option":"0","menu_option_text":"","menu_content_text":"","single_tag":"1","optional_option":"0","image":""},"extract":{"id":"33","title":"Extract Blog Entry","desc":"This will allow users to define an extract for an entry. Only this piece of the entry will be displayed on the main blog page and will show up in the RSS feed.","tag":"extract","useoption":"0","example":"This is an example!","switch_option":"0","menu_option_text":"","menu_content_text":"","single_tag":"0","optional_option":"0","image":""},"blog":{"id":"34","title":"Blog Link","desc":"This tag provides an easy way to link to a blog.","tag":"blog","useoption":"1","example":"Click me!","switch_option":"0","menu_option_text":"","menu_content_text":"","single_tag":"0","optional_option":"0","image":""},"entry":{"id":"35","title":"Blog Entry Link","desc":"This tag provides an easy way to link to a blog entry.","tag":"entry","useoption":"1","example":"Click me!","switch_option":"0","menu_option_text":"","menu_content_text":"","single_tag":"0","optional_option":"0","image":""},"optional":{"id":"36","title":"Optional","desc":"","tag":"optional","useoption":"0","example":"","switch_option":"0","menu_option_text":"","menu_content_text":"","single_tag":"0","optional_option":"1","image":""},"twitter":{"id":"37","title":"Twitter","desc":"A tag to link to a user's twitter account","tag":"twitter","useoption":"0","example":"@userName","switch_option":"0","menu_option_text":"","menu_content_text":"","single_tag":"0","optional_option":"0","image":"twitter.png"}}) ); ipb.vars['emoticon_url'] = "http://www.mpcforum.y0.pl/upload/public/style_emoticons/default"; //Search Setup ipb.vars['search_type'] = 'forum'; ipb.vars['search_type_id'] = 11; ipb.vars['search_type_2'] = 'topic'; ipb.vars['search_type_id_2'] = 4; //]]>
to mi się pokazuje jak chce dodać nowego posta i niepokazuje mi wszustkich dodatkowych opcji do edytowania tematu.
0
pokazuje mi się na każdym nowym temacie jak na niego kliknę i jak utworze nowy temat to nie mam dodatkowych opcji w edytorze tekstu ps kupiłem orginalną werjsje 3.0.5 i nie wiem czemu tak mam.
