Instalacja FURL 3.4 z polskimi znakami
Chcesz dodać przyjazne linki na swoje forum prostym i tanim kosztem? Nic trudnego! Skorzystaj z poniższego poradnika.
Wyślij na serwer oba pliki do głównego folderu forum (tam gdzie plik index.php oraz conf_global.php):
furl.zip
Następnie otwórz plik: sources/classes/class_display.php
Znajdź: [~ linii 417]
print $this->ipsclass->skin['_wrapper'];
Dodaj powyżej:
require ROOT_PATH."FURL.php";
Znajdź:
   // print the headers
Dodaj powyżej:
function make_url($title,$id,$type,$linktitle="",$tidlink=""){
global $ibforums;
$text = $title;
//Charachters must be in ASCII and certain ones aint allowed
$text = html_entity_decode ($text);
$text = preg_replace ("'<[\/\!]*?[^<>]*?>'si", "", $text);
//Polish Characters
$text = str_replace( "ą", "a", $text);
$text = str_replace( "Ą", "A", $text);
$text = str_replace( "ł", "l", $text);
$text = str_replace( "Ł", "L", $text);
$text = str_replace( "ó", "o", $text);
$text = str_replace( "Ó", "O", $text);
$text = str_replace( "ń", "n", $text);
$text = str_replace( "Ń", "N", $text);
$text = str_replace( "ć", "c", $text);
$text = str_replace( "Ć", "C", $text);
$text = str_replace( "ź", "z", $text);
$text = str_replace( "Ź", "z", $text);
$text = str_replace( "Ź", "Z", $text);
$text = str_replace( "ż", "z", $text);
$text = str_replace( "Ż", "Z", $text);
$text = str_replace( "ś", "s", $text);
$text = str_replace( "Ś", "S", $text);
$text = str_replace( "ę", "e", $text);
$text = str_replace( "Ę", "E", $text);
$text = str_replace( "€", "e", $text);
$text = str_replace(" / ","-",$text);
$text = str_replace("/","-",$text);
$text = str_replace("'","-",$text);
$text = str_replace(" - ","-",$text);
$text = str_replace("_","-",$text);
$text = str_replace(" ","-",$text);
$text = str_replace( "ä", "ae", $text);
$text = str_replace( "ö", "oe", $text);
$text = str_replace( "ü", "ue", $text);
$text = str_replace( "Ä", "Ae", $text);
$text = str_replace( "Ö", "Oe", $text);
$text = str_replace( "Ü", "Ue", $text);
$text = str_replace( "ß", "ss", $text);
$text = str_replace( "&", "and", $text);
$text = str_replace( "%", "Percent", $text);
$text = ereg_replace("[^A-Za-z0-9-]", "", $text);
$text = str_replace("----","-",$text);
$text = str_replace("---","-",$text);
$text = str_replace("--","-",$text);
if ($linktitle!=""){
$linktitle = " title=\"".$linktitle."\"";
if ($tidlink!=""){
$tidlink = " id=\"tid-link-{$tidlink}\"";
$furl = "<a{$tidlink} href=\"{$this->ipsclass->vars['board_url']}/{$text}-{$type}{$id}.html\"{$linktitle}>{$title}</a>";
return $furl;
Zapisz i wyślij.
Gotowe!
  • Odpowiedzi 80
  • Dodano
  • Ostatniej odpowiedzi
Top użytkownicy w tym temacie
Co sie mogło stać, jeśli FURL dział mi jedynie jako tematy a nie jako działy ?
Najpewniejsza przyczyna - zmodyfikowałeś plik .htaccess tak, że skasowałeś regułę przepisującą te linki :huh: Sprawdź to dokładnie.
DawPi
#FORUMS
RewriteRule ^forums\.html(.*)$ index.php?act=idx$1
# DO THE TOPIC URLS
RewriteRule ^(.*)-t([0-9][0-9]*)-s([0-9][0-9]*)\.html(.*)$ index.php?showtopic=$2&st=$3
RewriteRule ^(.*)-t([0-9][0-9]*)\.html(.*)$ index.php?showtopic=$2$3
Nie to.
Masz to:
# DO THE FORUM URLS
RewriteRule ^(.*)-new-topic-f([0-9]*)\.html(.*)$ index.php?act=Post&CODE=00&f=$2$3
RewriteRule ^(.*)-new-poll-f([0-9]*)\.html(.*)$ index.php?act=Post&CODE=10&f=$2$3
RewriteRule ^(.*)-f([0-9][0-9]*)\.html(.*)$ index.php?showforum=$2$3
 DO THE FORUM URLS
Wiec tak, forum do wglądu www.CyberSports.pl , a wiec jakieś inne pomysły ?
Wpis w FURL.php również jest taki sam:
	//FORUM URL
$this->ipsclass->skin['_wrapper'] = preg_replace("#<a href=\"{$boardurl}\?showforum=([0-9]*)\">(.+?)</a>#ie", "\$this->make_url('\\2','\\1','f')", $this->ipsclass->skin['_wrapper']);
$this->ipsclass->skin['_wrapper'] = preg_replace("#<a href='{$boardurl}\?showforum=([0-9]*)'>(.+?)</a>#ie", "\$this->make_url('\\2','\\1','f')", $this->ipsclass->skin['_wrapper']);
//FURL START
$oldskin = "";
$boardurl = "{$this->ipsclass->vars['board_url']}/index.php";
while ($this->ipsclass->skin['_wrapper']!=$oldskin){
$oldskin = $this->ipsclass->skin['_wrapper'];
//FORUM URL
//TOPIC URL
$this->ipsclass->skin['_wrapper'] = preg_replace("#<a id=\"tid-link-([0-9]*)\" href=\"{$boardurl}\?showtopic=([0-9]*)\" title=\"(.+?)\">(.+?)</a>#ie", "\$this->make_url('\\4','\\2','t','\\3','\\1')", $this->ipsclass->skin['_wrapper'], 1);
//MEMBER PROFILES
$this->ipsclass->skin['_wrapper'] = preg_replace("#<a href='{$boardurl}\?showuser=([0-9]*)'>(.+?)</a>#ie", "\$this->make_url('\\2','\\1','m')", $this->ipsclass->skin['_wrapper'], 1);
$this->ipsclass->skin['_wrapper'] = preg_replace("#<a href=\"{$boardurl}\?showuser=([0-9]*)\">(.+?)</a>#ie", "\$this->make_url('\\2','\\1','m')", $this->ipsclass->skin['_wrapper'], 1);
jest
  • 8 miesięcy temu...
Sprawdź kodowanie znaków w pliku class_display.php i ustaw zależnie od kodowania na forum ( pewnie ISO-8859-2 lub UTF-8 ).
Dzięki pomogło przestawienie kodowania na ISO-8859-2 (plik edytowałem PSPad editor)
  • 1 miesiąc temu...
Zrobilem to wszystko, co pisaliscie, i mam 2 problemy:
1. Nie zmienia mi linków do działów
"index.php?showforum=49"
2. temat sie nazywa "Propozycja II Część" a tworzy mi linka: "Propozycja-II-Czec-t9543.html" bez "s"
Co moze byc problemem ??
Nie po kolei:
Ad 2 - ponieważ plik class_display.php nie zakodowałeś w ( patrząc na Twoje forum ) ISO-8859-2 - możesz użyć do tego choćby PSPad ( taki program ). Sprawdź to dobrze ponieważ to na 100% ten problem. Kiedyś to wielokrotnie przerabiałem..
Ad 1 - faktycznie dziwna sprawa. :) Na pewno masz poprawne pliczki? ;)
Hym, wcześniej podobny problem miał Xawier - być może łączy Was 'wspólny' serwer. Jaki i gdzie masz kupiony serwer?
Napewno nie, bo mam serwer dedykowany pod forum. A odnosnie AD2, to jak sie to konwertuje ?
No właśnie, Xawier też miał - sprawdź czy aby na pewno obsługę mod rewrite masz poprawnie ustawioną. :)
Ad 2 - z menu Format ( przykład na programie PSPad ) wybierasz poprawne kodowanie, zapisujesz i wysyłasz ten plik. Ja tak robię i nie ma problemów.
mam problem z tym modem ponieważ wgrałem wszystko i nic nie działa jak było tak jest.Co może być przyczyną?
http://webcityfile.pl/index.php?showforum=109
Dobrze wykonałeś edycję pliku class_display.php? Tylko proszę nie podawaj mi tutaj treści tego pliku bym Ci miał to sprawdzać. Ja nie wiem co wy tak ostatnio się nauczyliście, że będę was wyręczać we wszystkim. :bubble:
