RESOLVED: problem with Admin CP ?
I can't access to components via ACP .. everything else is working fine .. but when I click on Components only loading .. loading .. it's takes ages ? What can be problem ??
Hello gami,
probably you have many mods in UMI and UMI is your first active component with enables callback functions. :unsure:
So go to:
ACP > ADMIN > Components > Manage Components
And by clicking on arrow_down.png beside UMI put it down. ;)
but what should I get with this one ?? this is only order for them .. and in here is not all mods I have on forum .. why is that ??
I have men .. but I can't access to Components .. that's the problem .. it's loading loading but not opening this page for me ..
gami: maybe this is another issue. OR try disable UMI component in ACP > ADMIN > Components > Manage Components and then check. If you will have still problem with opening COMPONENTS tab then i think this is causes by another reason unfortunatelly.
It's not UMI I got this error
Date: Thu, 02 Oct 2008 16:18:40 +0200
Error Number: 1064
Error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'and approved IN (0,1) LIMIT 0,10' at line 1
IP Address: xx.xx.xx.xx
Page: /forum/index.php?s=&act=xmlout&do=similar&title=Advanced%20System%20Optimizer%202.20.4.726%20(#1%20soft%20in%20world)&fid=14&__=1222956561875
mySQL query error: SELECT * FROM ibf_topics WHERE title LIKE '%Advanced System Optimizer 2.20.4.726 (%' AND forum_id= and approved IN (0,1) LIMIT 0,10
(V88)Similar Topics 1.0.0
I found out via FTP :unsure: matter of fact I have 2 of them not same .. but 2
(MPFF) Similar Topics 1.0 MBFF
Edytowane przez gami
Strange situation.. I really don't know what's happen.. ;/ Maybe if you ask Vadim ( authos of this mod ) then he could tell more about that.
I must think but i afraid i'm not able to help you. ;/
(V88)Similar Topics 1.0.0 vadim88 http://www.invisionmodding.com/forums/ 2.2 st_no_topic_title No Topic Title lang_forum st_no_topic_found No Topics Found lang_forum st_similar_title Similar Topics in this forum lang_forum skin_post <script language="javascript" type="text/javascript"> <!-- var unselectedbutton = "{$this->ipsclass->vars['img_url']}/topic_unselected.gif"; var selectedbutton = "{$this->ipsclass->vars['img_url']}/topic_selected.gif"; var lang_gobutton = "{$this->ipsclass->lang['f_go']}"; var lang_suredelete = "{$this->ipsclass->lang['cp_js_delete']}"; var lang_otherpage = "{$this->ipsclass->lang['jscript_otherpage']}"; var lang_clickhold = "{$this->ipsclass->lang['js_clickhold']}"; var perm_can_edit = $can_edit; var perm_can_open = $can_open; var perm_can_close = $can_close; var perm_max_length = {$this->ipsclass->vars['topic_title_max_len']}; // Set up img vars var img_markers = { 'bc_new.gif' : 'bc_nonew.gif', 'bf_new.gif' : 'bf_nonew.gif', 'br_new.gif' : 'br_nonew.gif' }; var regex_markers = 'bc_new.gif|bf_new.gif|br_new.gif'; //--> </script> <script type="text/javascript" src="jscripts/ipb_forum.js"></script> <div class="borderwrap"> <div class="maintitle"> <p>{$title}</p> </div> <table class='ipbtable' cellspacing="1" cellpadding="1"> <tr> <th align="center"> </th> <th align="center"> </th> <th width="50%" nowrap="nowrap">{$this->ipsclass->lang['h_topic_title']}</th> <th width="7%" style="text-align:center" nowrap="nowrap">{$this->ipsclass->lang['h_replies']}</th> <th width="14%" style="text-align:center" nowrap="nowrap">{$this->ipsclass->lang['h_topic_starter']}</th> <th width="7%" style="text-align:center" nowrap="nowrap">{$this->ipsclass->lang['h_hits']}</th> <th width="22%" nowrap="nowrap">{$this->ipsclass->lang['h_last_action']}</th> </tr> {$content} <tr> <td class='formbuttonrow' align='center' colspan="7"> <!-- No Content --> </td> </tr> </table> </div><br /> <script type='text/javascript'> //<!#^#|CDATA| // INIT links for editing if ( use_enhanced_js && perm_can_edit ) { forum_init_topic_links(); } //|#^#]> </script> similar_wrapper $title="", $content="" skin_post <!-- Begin Similar Topic Entry {$data['tid']} --> <tr> <td align="center" class="$class2" id='tid-folder-{$data['tid']}'>{$data['folder_img']}</td> <td align="center" class="$class2">{$data['topic_icon']}</td> <td class="$class2" valign="middle"> <div style='float:right'>{$data['_rate_img']}</div> <div> {$data['go_new_post']}{$data['prefix']} {$data['attach_img']}<span id='tid-span-{$data['tid']}'><a id="tid-link-{$data['tid']}" href="{$this->ipsclass->base_url}showtopic={$data['tid']}" title="{$this->ipsclass->lang['topic_started_on']} {$data['start_date']}">{$data['title']}</a></span> {$data['PAGES']} <div class="desc"><span id='tid-desc-{$data['tid']}'>{$data['description']}</span></div> </div> </td> <td align='center' class="$classposts"> {$data['posts']} <if="$data['_hasqueued'] == 1 and $inforum == 1">  <a href="{$this->ipsclass->base_url}showtopic={$data['tid']}&modfilter=invisible_posts"><{BC_QUEUED_POSTS}></a> </if> </td> <td align="center" class="$class2">{$data['starter']}</td> <td align="center" class="$class1">{$data['views']}</td> <td class="$class2"><span class="lastaction">{$data['last_post']}<br /><a href="{$this->ipsclass->base_url}showtopic={$data['tid']}&view=getlastpost">{$data['last_text']}</a> <b>{$data['last_poster']}</b></span></td> </tr> <!-- End Similar Topic Entry {$data['tid']} --> similar_row $data="",$class1='row2',$class2='row1',$classposts='row2',$inforum=0 add forums similar_topics tinyint(1) 0
I found only this ..
This error:
Error Number: 1064
is not related to any mods in ACP ( UMI ) but to forum.
Hm, i think you have to many topics on your forum and this mod doesn't have much power from host and go down.
I don't know situation in your ACP and SQL database but this long loading COMPONENTS tab must be causing by another reason. Right now i don't know which. For fix this i'll must have FTP access but this is private help now. :unsure:
I manage to fix this .. somehow .. I simply disable it for each forum and now it works .. You can close this one .. tnx for help anyway ..
