ROZWIĄZANY: Problem z Driver Error po odinstalowaniu modyfikacji
Mam dziwny problem
dziś na domenie głównej pojawił się
codegame.pl Driver Error
a na forum jest biała strona
dodam że dziś zainstalowałem IP.Download i odinstalowałem Video System a wcześniej nic się nie działo
log z dzisiejszego cgi.
Date: Fri, 13 May 2011 11:43:27 +0000
Error: 2013 - Lost connection to MySQL server at 'reading initial communication packet', system error: 104
IP Address: 77.91.28.166 - /index.php?/topic/830-15-01-komendy-w-trybie-single-player-minecraft-v28-1/page__st__140
Date: Fri, 13 May 2011 11:43:30 +0000
Error: 2002 - Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
Date: Fri, 13 May 2011 11:43:31 +0000
IP Address: 79.185.148.110 - /index.php?app=core&module=task
Date: Fri, 13 May 2011 21:23:20 +0000
Error: 1146 - Table 'codegame_pl.codegame_videos' doesn't exist
IP Address: 77.254.234.45 - /index.php?/videos/view-19-reklama-codegame/
mySQL query error: SELECT v.tid, v.cid, v.author_id, v.author_name, v.date, v.title, v.status, v.last_updated, v.views, v.seo_title, v.thumbnail, v.members_seo_name FROM codegame_videos v WHERE v.status=0 ORDER BY date desc LIMIT 0,5
| admin/applications_addon/other/uportal/modules_public/uportal/uportal.php(1171) : eval()'d code| [classVideos].video_block                                                     | 14                |
| admin/applications_addon/other/uportal/modules_public/uportal/uportal.php  | [].eval        | 1171              |
| admin/applications_addon/other/uportal/modules_public/uportal/uportal.php  | [public_uportal_uportal_uportal].customBlock                                  | 191               |
| admin/applications_addon/other/uportal/modules_public/uportal/uportal.php  | [public_uportal_uportal_uportal].getCustomBlocks                              | 64                |
| admin/sources/base/ipsController.php                                       | [public_uportal_uportal_uportal].doExecute                                    | 285               |
Date: Fri, 13 May 2011 21:24:59 +0000
IP Address: 67.195.111.52 - /index.php?/videos/view-12-l2phx-3533166-freya/
Date: Fri, 13 May 2011 21:26:55 +0000
IP Address: 83.20.210.73 - /
Date: Fri, 13 May 2011 21:29:07 +0000
IP Address: 77.200.26.149 - /
Date: Fri, 13 May 2011 21:29:09 +0000
IP Address: 77.200.26.149 - /index.php
Date: Fri, 13 May 2011 21:45:17 +0000
Date: Fri, 13 May 2011 21:45:20 +0000
Date: Fri, 13 May 2011 21:45:24 +0000
IP Address: 95.108.150.235 - /
Date: Fri, 13 May 2011 21:45:25 +0000
Date: Fri, 13 May 2011 21:45:26 +0000
Date: Fri, 13 May 2011 21:45:31 +0000
Date: Fri, 13 May 2011 21:45:34 +0000
Date: Fri, 13 May 2011 21:46:05 +0000
Date: Fri, 13 May 2011 21:46:27 +0000
IP Address: 77.254.234.45 - /index.php?app=uportal
Date: Fri, 13 May 2011 21:46:43 +0000
Date: Fri, 13 May 2011 21:47:37 +0000
Date: Fri, 13 May 2011 21:48:38 +0000
Date: Fri, 13 May 2011 21:49:50 +0000
Date: Fri, 13 May 2011 21:50:25 +0000
Date: Fri, 13 May 2011 21:51:56 +0000
Date: Fri, 13 May 2011 21:52:37 +0000
Date: Fri, 13 May 2011 21:53:07 +0000
Date: Fri, 13 May 2011 21:53:51 +0000
Date: Fri, 13 May 2011 21:53:54 +0000
Date: Fri, 13 May 2011 21:56:00 +0000
Date: Fri, 13 May 2011 21:57:48 +0000
Date: Fri, 13 May 2011 22:00:27 +0000
IP Address: 66.249.72.39 - /index.php?/videos/view-11-zastera/
Date: Fri, 13 May 2011 22:00:36 +0000
Date: Fri, 13 May 2011 22:02:42 +0000
Date: Fri, 13 May 2011 22:02:43 +0000
Date: Fri, 13 May 2011 22:02:45 +0000
Edytowane przez lumota
Amazing Game Website Templates for those who want to stand out from others.
Professional IPS Themes - Gaming Invision Community Themes, Forum Skins and Game UI Templates.
Forum Templates for Clans and Guilds, Web and Game Developers.
Dodałeś jakiś blok pewnie na portalu z kodem używającym danych z tabeli systemu video. Usuń go, a problem zniknie.
usunąłem go i teraz nic się nie wyświetla
pusta strona
w logach dalej jest to samo
Ostatni błąd SQL (dziś, 11:02 )
patrzyłem czy zostało jakieś rozszerzenie ale nie ma
znalazłem coś takiego:
[13-May-2011 22:01:35] PHP Fatal error:  Call to undefined method skin_global_4::_guestMessage() in /home/codegame/public_html/codegame/cache/skin_cache/cacheid_4/skin_global.php on line 395
w folderze głównym zrobił się plik error_log_php i w nim to jest
pousuwałem je
i dalej tworzy się ten plik w głównym katalogu z tym
[13-May-2011 22:42:17] PHP Fatal error:  Call to undefined method skin_global_4::_guestMessage() in /home/codegame/public_html/codegame/cache/skin_cache/cacheid_4/skin_global.php on line 395
przebudowanie nie pomogło
A jak nie pomoże to przeinstaluj moda od wyświetlania wiadomości dla gości.
jest problem bo ja nie miałem takiego moda
na pewno nie miałem takiej modyfikacji
Użyj narzędzia numer 3, a potem numer 1 - mowa oczywiście o narzędziach skina
zrobiłem tak od razu jak usunąłem tą tabele video sys z portalu
i nie pomogło
No to coś się odwołuje do tego bitu skina.. Najpierw sprawdź sam skin w poszukiwaniu frazy 'guestmessage'. A jak nie znajdzie to pobierz pliki z FTP i je przeczesz. Przecież nie sądzisz, że to ot tak się pojawia.
A przypadkiem nie używasz któregoś skina od Oliviera (SKINBOX)? Oni zdaje się mają w skinach takie bity jak "_guestMessage" spróbuj zmienić skin na domyślny przez ACP, albo wrzuć plik skinchange.php na serwer i wywołaj zmianę skina przez
www.codegame.pl/skinchnage.php?id=1
dzięki maxx to przez skin coś się w nim pomieszało i padł
zmieniłem na podstawowy i działa
