ROZWIĄZANY: Menu - problem ;(
Witajcie,
Dziś chciałem dodać link do menu głównego.
Udało się, aczkolwiek nie wyświetla się bannerek (tło).
Forum: http://slayergames.pl , wersja 3.1.4.
<if test="!ipsRegistry::$applications['forums']['app_hide_tab']"><li id='nav_discussion' class='{parse variable="forumActive"}'><a href='{parse url="act=idx" seotitle="false" base="public"}' title='{$this->lang->words['go_to_discussion']}'><span>{$this->lang->words['discussion']}</span></a></li></if>
					<if test="!ipsRegistry::$applications['members']['app_hide_tab']"><li id='nav_members' class='{parse variable="membersActive"}'><a href='{parse url="app=members" base="public" template="members_list" seotitle="false"}' title='{$this->lang->words['go_to_memberlist']}'><span>{$this->lang->words['tb_mlist']}</span></a></li></if>
					<if test="applicationsloop:|:is_array($header_items['applications']) AND count($header_items['applications'])">
						<foreach loop="applications:$header_items['applications'] as $data">
							<if test="showingapp:|:$data['app_show']">
								{parse variable="appActive" default="" oncondition="$data['app_active']" value="active"}
								<li id='nav_app_{$data['app_dir']}' class='{parse variable="appActive"}'><a href='{parse url="{$data['app_link']}" seotitle="false" base="public"}' title='{parse expression="sprintf( $this->lang->words['go_to_prefix'], IPSLib::getAppTitle($data['app_dir']) )"}'><span>{IPSLib::getAppTitle($data['app_dir'])}</span></a></li>
						</foreach>
<li id='nav_app' class='left <if test="$this->request['showuser']">active</if>'><a href='http://bany.slayergames.pl'>AMXBans</a></li>
</ul>
               </div></div>
			<if test="pmbox:|:is_array( $items['notifications'] )">
Bardzo proszę o pomoc!
Pozdrawiam,
Edytowane przez Slawo
Daj tak :D
                                                       </foreach>
</ul>
               </div></div>
A tak
                                                       </foreach>
                               <li id='nav_app'><a href='http://bany.slayergames.pl'>AMXBans</a></li>
</ul>
               </div></div>
                                                       </foreach>
<li id='nav_custom_link' class='left><a href='http://bany.slayergames.pl' title='AMXBans'><span>AMXBans</span></a></li>
</ul>
               </div></div>
Powiedz czy dziala?
Teraz się wyświetla sam tekst, bez linku i bez tła.
Można zobaczyć na slayergames.pl
<li id='nav_amxbans' class='left'><a title='AMXBans' href='http://bany.slayergames.pl'><span>AMXBans</span></a></li>
To musi działać, bo sprawdzałem w FireBugu.
Dziękuje ;) Śmiga jak ta lala.
A jak mogę zapytać, co to jest firebug?
