wgrałem sobie modyfikacje Referal System i użyłem trzech sposobów na polecenie i tak:
1: Link - nie został dodany pkt
2: Gmail po probie zalogowania się na konto gmail wyskakuje error
Warning: curl_setopt() [function.curl-setopt]: CURLOPT_FOLLOWLOCATION cannot be activated when in safe_mode or an open_basedir is set in /home/a2mir102/domains/muserwer.com.pl/public_html/sources/components_public/utr_classes/utr_gmail.php on line 86
Warning: curl_setopt() [function.curl-setopt]: open_basedir restriction in effect. File() is not within the allowed path(s): (/home/a2mir102/:/tmp:/usr/local/lib/php/) in /home/a2mir102/domains/muserwer.com.pl/public_html/sources/components_public/utr_classes/utr_gmail.php on line 101
Warning: curl_setopt() [function.curl-setopt]: open_basedir restriction in effect. File() is not within the allowed path(s): (/home/a2mir102/:/tmp:/usr/local/lib/php/) in /home/a2mir102/domains/muserwer.com.pl/public_html/sources/components_public/utr_classes/utr_gmail.php on line 102
Warning: curl_setopt() [function.curl-setopt]: CURLOPT_FOLLOWLOCATION cannot be activated when in safe_mode or an open_basedir is set in /home/a2mir102/domains/muserwer.com.pl/public_html/sources/components_public/utr_classes/utr_gmail.php on line 117
Warning: curl_setopt() [function.curl-setopt]: open_basedir restriction in effect. File() is not within the allowed path(s): (/home/a2mir102/:/tmp:/usr/local/lib/php/) in /home/a2mir102/domains/muserwer.com.pl/public_html/sources/components_public/utr_classes/utr_gmail.php on line 122
Warning: curl_setopt() [function.curl-setopt]: open_basedir restriction in effect. File() is not within the allowed path(s): (/home/a2mir102/:/tmp:/usr/local/lib/php/) in /home/a2mir102/domains/muserwer.com.pl/public_html/sources/components_public/utr_classes/utr_gmail.php on line 123
Warning: curl_setopt() [function.curl-setopt]: CURLOPT_FOLLOWLOCATION cannot be activated when in safe_mode or an open_basedir is set in /home/a2mir102/domains/muserwer.com.pl/public_html/sources/components_public/utr_classes/utr_gmail.php on line 140
Warning: curl_setopt() [function.curl-setopt]: open_basedir restriction in effect. File() is not within the allowed path(s): (/home/a2mir102/:/tmp:/usr/local/lib/php/) in /home/a2mir102/domains/muserwer.com.pl/public_html/sources/components_public/utr_classes/utr_gmail.php on line 143
Warning: curl_setopt() [function.curl-setopt]: open_basedir restriction in effect. File() is not within the allowed path(s): (/home/a2mir102/:/tmp:/usr/local/lib/php/) in /home/a2mir102/domains/muserwer.com.pl/public_html/sources/components_public/utr_classes/utr_gmail.php on line 144
3: wysłanie na e-mail - nie dochodzi mail.
Moje forum istnieje dzięki pomocy DawPi
Zdaje się, że problem z dostępem. Może z chmodami na ten folder i plik pokombinuj?
Don Vito Corleone
Nie ma czasami włączonego safe_mod?
TOOLS & SETTINGS>General Configuration>Use Safe Mode Skins?
mam na NO.
ohh, nawet jak to zrobiłem to zadziałało^^
dziwny jest ten świat.
mam jeszcze jedno pytanko.
Zrobiłem sobie aktywacje e-mail i jak zrobić, że user dostaje pkt dopiero jak konto zostanie zaaktywowane?
Zgodne, nie ma 'break\'a'.
Jeśli nie ma takiej opcji w ustawieniach to nie można łatwym sposobem tego zrobić.
