A więc zainstalowałem dzisiaj IP.SEO 1.5.1
Zauważyłem, że nie można wchodzić w działy itp
http://pro-gamming.pl , bo wyskakuje '404 not found'
Dodatkowo sprawdziłem w bazie i nie utworzyło tabeli w ogóle, a o to wycinek z logów :
Date: Sat, 03 Dec 2011 09:38:48 +0000 Error: 1146 - Table 'bebek112_ipboard.ibf_seo_meta' doesn't exist IP Address: 83.2.112.7 - /admin/index.php?adsess=6ff322a627a8a4745d828974468e5363&app=core&module=applications&section=setup&do=finish&app_directory=ipseo&type=install&version=10000 ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- mySQL query error: SELECT * FROM ibf_seo_meta .--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------. | File | Function | Line No. | |----------------------------------------------------------------------------+-------------------------------------------------------------------------------+-------------------| | admin/sources/base/ipsRegistry.php | [ipSeoCaches].rebuildMetaTagCache | 3285 | '----------------------------------------------------------------------------+-------------------------------------------------------------------------------+-------------------' | admin/applications/core/modules_admin/applications/setup.php | [ips_CacheRegistry].rebuildCache | 220 | '----------------------------------------------------------------------------+-------------------------------------------------------------------------------+-------------------' | admin/applications/core/modules_admin/applications/setup.php | [admin_core_applications_setup].finish | 150 | '----------------------------------------------------------------------------+-------------------------------------------------------------------------------+-------------------' | admin/sources/base/ipsController.php | [admin_core_applications_setup].doExecute | 302 | '----------------------------------------------------------------------------+-------------------------------------------------------------------------------+-------------------'
Edytowane przez DawPi
Edycja nazwy tematu. Na przyszłość staraj się dokładniej opisywać swoje pytania/problemy.
Znajdziesz mnie na LinkedIn
Automatyczna wiadomość
Temat przeniesiony z forum:
"Invision Power Board → Invision Power Board 3.2 → Modyfikacje - pomoc"
do:
"Invision Power Board → Aplikacje Invision Power Services → IP.SEO"
Skasowałem tabele z bazy mysql, zainstalowałem ip seo na nowo.
W przeglądzie bazy danych wszystko ok, więc co muszę zrobić aby te tematy itp działały?
Jaki jest kod do htaccess
Edytowane przez TeeZik
