ROZWIĄZANY: Problem z polaczeniem z Baza Danych
Pokaż logi z folderu /cache.
http://screenshooter...6460591/furkgvg
w Errorze z dzis dodc duzo jest bledów takich :
http://screenshooter...6460591/enddxmv
Date: Sat, 10 Dec 2011 12:19:37 +0000
Error: 1064 - Something is wrong in your syntax obok '' w linii 1
IP Address: 223.166.137.75 - /
mySQL query error: SELECT avatar_location, avatar_type, pp_thumb_width, pp_thumb_height, pp_thumb_photo FROM profile_portal WHERE pp_member_id=
| File																	   | Function																	  | Line No.		  |
| admin/applications_addon/other/shoutbox/sources/classes/library.php	    | [skin_shoutbox_6].shout_row												   | 710			   |
| admin/applications_addon/other/shoutbox/sources/classes/library.php	    | [shoutboxLibrary].parse_shout												 | 324			   |
| hooks/shoutboxGlobalShoutbox_b4502eb40f604769cd649c4263dcb397.php		  | [shoutboxLibrary].return_shouts											   | 130			   |
| admin/sources/classes/output/publicOutput.php							  | [shoutboxGlobalShoutbox].getOutput										    | 3371			  |
| admin/sources/classes/output/publicOutput.php							  | [output].templateHooks													    | 2673			  |
| admin/applications/forums/modules_public/forums/boards.php				 | [output].sendOutput														   | 127			   |
| admin/sources/base/ipsController.php									   | [public_forums_forums_boards].doExecute									   | 302			   |
Date: Sat, 10 Dec 2011 12:19:40 +0000
IP Address: 83.28.142.35 - /
Date: Sat, 10 Dec 2011 12:19:47 +0000
IP Address: 124.244.87.159 - /
Date: Sat, 10 Dec 2011 12:19:48 +0000
IP Address: 113.64.188.182 - /
Date: Sat, 10 Dec 2011 12:20:08 +0000
IP Address: 218.86.49.93 - /
Date: Sat, 10 Dec 2011 12:20:17 +0000
IP Address: 110.86.1.242 - /
Date: Sat, 10 Dec 2011 12:20:29 +0000
IP Address: 59.61.66.52 - /
Date: Sat, 10 Dec 2011 12:20:37 +0000
IP Address: 83.28.142.35 - /index.php
Date: Sat, 10 Dec 2011 12:20:40 +0000
Date: Sat, 10 Dec 2011 12:20:42 +0000
IP Address: 124.193.106.56 - /
Edytowane przez Prizmo
http://scr.hu/1p4s/in3pa
Po usunieciu Sb Forum zaczelo dzialac :)
teraz Zainstaluje i Zobaczymy Co sie stanie ;)
Edit:
Po zainstalowaniu Wyskakuje Takie cos na Forum:
http://screenshooter...6460591/bjuvbng
Po wylaczeniu Sb w PA Forum Spowrotem dziala.
Nadpisaywalem wszystkie pliki instalowem Od nowa.
Co Moze byc nie tak?
