Witam!! Zainstalowałem wymienioną w temacie aplikacje, i mam to z crona:
PHP Notice: Constant IPS_AREA already defined in /home/platne/csone/public_html/forum/initdata.php on line 139
13:00:02 - Sitemap generation started.
13:00:02 - Running plugins for IPS applications.
13:00:02 - Running plugins for: ipseo
13:00:02 - - - Running plugin: content_database_categories
13:00:02 - - - - Generated 0 sitemaps.
13:00:02 - - - Running plugin: chat
13:00:02 - - - Running plugin: topics
Done: 0, 104, 204, 305, 405, 577, 678, 778, 878, 979, 1079, 1179, 1279, 1379, 1479, 1579, 1679, 1779, 1880, 1980, 2080, 2180, 2280, 2380, 2480, 2580, 2680, 2780, 2880, 2980, 3080, 3180, 3280, 3380, 3480, 3580, 3680, 3780, 3880, 3980, 4080, 4180, 4281, 4382, 4484, 4585, 4685, 4786, 4886, 4988, 5088, 5189, 5289, 5389, 5489, 5591, 5691, 5791, 5893, 5993, 6093, 6193, 6293, 6394, 6494, 6599, 6703, 6805, 6906, 7007, 7110, 7213, 7315, 7417, 7522, 7625, 7728, 7830, 7933, 8034, 8135, 8240, 8342, 8444, 8549, 8650, 8752, 8853, 8956, 9059, 9164, 9268, 9372, 9476, 9581, 9687, 9790, 9897, 10001, 10107, 10214, 10326, 10434, 10542, 10646, 10754, 10860, 10968, 11075, 11181, 11289, 11390, 11496, 11604, 11708, 11816, 11920, 12020, 12123, 12230, 12340, 12447, 12563, 12676, 12793, 12898, 13007, 13116, 13220, 13326, 13434, 13546, 13656, 13761, 13869, 13977, 14079, 14183, 14293, 14408, 14515, 14620, 14723, 14831, 14936, 15037, 15137, 15239, 15342, 15448, 15549, 15650, 15751, 15855, 15959, 16066, 16
170, 16272, 16372, 16472, 16572, 16672, 16772, 16872, 16972, 17072, 17172, 17272,
13:00:39 - - - - Generated 2 sitemaps.
13:00:39 - - - - - File 1, added 10000 URLs.
13:00:39 - - - - - File 2, added 7341 URLs.
13:00:39 - - - Running plugin: content_database_records
13:00:39 - - - - Generated 0 sitemaps.
13:00:39 - - - Running plugin: downloads_categories
13:00:39 - - - Running plugin: core
13:00:39 - - - - Generated 1 sitemaps.
13:00:39 - - - - - File 1, added 1 URLs.
13:00:39 - - - Running plugin: gallery_albums
13:00:39 - - - Running plugin: blog_entries
13:00:39 - - - Running plugin: downloads_files
13:00:39 - - - Running plugin: gallery_images
13:00:39 - - - Running plugin: content_pages
13:00:39 - - - Running plugin: forums
13:00:40 - - - - Generated 1 sitemaps.
13:00:40 - - - - - File 1, added 118 URLs.
13:00:40 - - - Running plugin: calendar
13:00:40 - - - - Generated 0 sitemaps.
13:00:40 - - - Running plugin: nexus_products
13:00:40 - - - Running plugin: blogs
13:00:40 - - - Running plugin: nexus_categories
13:00:40 - Running plugins for third party applications.
13:00:40 - No plugins to run for: advancedtagsprefixes
13:00:40 - No plugins to run for: cp
13:00:40 - No plugins to run for: topictemplate
13:00:40 - No plugins to run for: tagss
13:00:40 - No plugins to run for: updatemodules
13:00:40 - No plugins to run for: shoutbox
13:00:40 - Sitemap generation finished.
13:00:40 - Could not write sitemap index file to: /home/platne/csone/public_html/forum/www.csone.eu
Automatyczna wiadomość
Temat przeniesiony z forum:
"Invision Power BoardInvision Power Board 3.3Ogólny support IPB"
do:
"Invision Power BoardAplikacje Invision Power ServicesIP.SEO"
Sprawdź czy podany plik masz z poprawną zawartością - a najlepiej pobierz paczkę IP.Board i nadpisz ten plik.
Sprawdź czy masz a jak nie to stwórz plik sitemap.xml i daj mu prawa 777 (w głównym katalogu forum)
Edytowane przez elroy
Teraz mam taki błąd:
19:00:01 - Sitemap generation started.
19:00:01 - Running plugins for IPS applications.
19:00:01 - Running plugins for: ipseo
19:00:01 - - - Running plugin: content_database_categories
19:00:01 - - - - Generated 0 sitemaps.
19:00:01 - - - Running plugin: chat
19:00:01 - - - Running plugin: topics
Done: 0, 104, 204, 305, 405, 577, 678, 778, 878, 979, 1079, 1179, 1279, 1379, 1479, 1579, 1679, 1779, 1879, 1980, 2080, 2180, 2280, 2380, 2480, 2580, 2680, 2780, 2880, 2980, 3080, 3180, 3280, 3380, 3480, 3580, 3680, 3780, 3880, 3980, 4080, 4180, 4281, 4382, 4484, 4585, 4685, 4786, 4886, 4988, 5088, 5189, 5289, 5389, 5489, 5591, 5691, 5791, 5893, 5993, 6093, 6193, 6293, 6393, 6494, 6599, 6703, 6805, 6906, 7006, 7108, 7212, 7315, 7417, 7522, 7625, 7727, 7830, 7933, 8034, 8135, 8240, 8342, 8442, 8548, 8650, 8752, 8853, 8955, 9058, 9164, 9268, 9372, 9475, 9581, 9687, 9790, 9897, 10001, 10106, 10214, 10325, 10434, 10541, 10646, 10754, 10860, 10967, 11072, 11180, 11287, 11390, 11496, 11604, 11708, 11816, 11920, 12020, 12123, 12228, 12339, 12446, 12563, 12675, 12793, 12897, 13007, 13116, 13220, 13325, 13434, 13545, 13656, 13761, 13868, 13977, 14079, 14183, 14292, 14408, 14515, 14618, 14723, 14831, 14935, 15037, 15137, 15239, 15342, 15448, 15549, 15650, 15751, 15855, 15959, 16066, 16
169, 16272, 16372, 16472, 16572, 16672, 16772, 16872, 16972, 17072, 17172, 17272,
19:00:32 - - - - Generated 2 sitemaps.
19:00:32 - - - - - File 1, added 10000 URLs.
19:00:32 - - - - - File 2, added 7348 URLs.
19:00:32 - - - Running plugin: content_database_records
19:00:32 - - - - Generated 0 sitemaps.
19:00:32 - - - Running plugin: downloads_categories
19:00:32 - - - Running plugin: core
19:00:32 - - - - Generated 1 sitemaps.
19:00:32 - - - - - File 1, added 1 URLs.
19:00:32 - - - Running plugin: gallery_albums
19:00:32 - - - Running plugin: blog_entries
19:00:32 - - - Running plugin: downloads_files
19:00:32 - - - Running plugin: gallery_images
19:00:32 - - - Running plugin: content_pages
19:00:32 - - - Running plugin: forums
19:00:32 - - - - - File 1, added 118 URLs.
19:00:32 - - - Running plugin: calendar
19:00:32 - - - Running plugin: nexus_products
19:00:32 - - - Running plugin: blogs
19:00:32 - - - Running plugin: nexus_categories
19:00:32 - Running plugins for third party applications.
19:00:32 - No plugins to run for: advancedtagsprefixes
19:00:32 - No plugins to run for: cp
19:00:32 - No plugins to run for: topictemplate
19:00:32 - No plugins to run for: tagss
19:00:32 - No plugins to run for: updatemodules
19:00:32 - No plugins to run for: shoutbox
19:00:32 - Sitemap generation finished.
19:00:32 - Wrote sitemap file to: /home/platne/csone/public_html/forum/sitemap.xml
19:00:32 - Pinging search engines with updated sitemap.
19:00:32 - Successfully pinged Google.
19:00:33 - Successfully pinged Bing.
19:00:33 - Successfully pinged Ask.
19:00:38 - Failed to ping Moreover.
