Witam
Tak więc dziś postanowiłem włączyć na forum portal wchodząc w zakładkę portal zobaczyłem takie błędy:
[long]Warning: Invalid argument supplied for foreach() in /home/raszid/domains/antero.pl/public_html/forum/admin/applications_addon/ips/portal/modules_public/portal/portal.php on line 107
Warning: Cannot modify header information - headers already sent by (output started at /home/raszid/domains/antero.pl/public_html/forum/admin/applications_addon/ips/portal/modules_public/portal/portal.php:107) in /home/raszid/domains/antero.pl/public_html/forum/admin/sources/classes/output/formats/html/htmlOutput.php on line 114
Warning: Cannot modify header information - headers already sent by (output started at /home/raszid/domains/antero.pl/public_html/forum/admin/applications_addon/ips/portal/modules_public/portal/portal.php:107) in /home/raszid/domains/antero.pl/public_html/forum/admin/sources/classes/output/formats/html/htmlOutput.php on line 127
Warning: Cannot modify header information - headers already sent by (output started at /home/raszid/domains/antero.pl/public_html/forum/admin/applications_addon/ips/portal/modules_public/portal/portal.php:107) in /home/raszid/domains/antero.pl/public_html/forum/admin/sources/classes/output/formats/html/htmlOutput.php on line 136
Warning: Cannot modify header information - headers already sent by (output started at /home/raszid/domains/antero.pl/public_html/forum/admin/applications_addon/ips/portal/modules_public/portal/portal.php:107) in /home/raszid/domains/antero.pl/public_html/forum/admin/sources/classes/output/formats/html/htmlOutput.php on line 137
Warning: Cannot modify header information - headers already sent by (output started at /home/raszid/domains/antero.pl/public_html/forum/admin/applications_addon/ips/portal/modules_public/portal/portal.php:107) in /home/raszid/domains/antero.pl/public_html/forum/admin/sources/classes/output/formats/html/htmlOutput.php on line 141[/long]
Czy ktoś może mnie poinstruować co należało by zrobić aby to poprawić, nie jestem orłem z PHP ale coś tam ogarniam.
Z góry dziękuje wszystkim za pomoc ...
A tu plik portal.php
[long]<?php
* <pre>
* Invision Power Services
* IP.Board v3.1.4
* IP.Portal
* Last Updated: $Date: 2010-10-21 14:02:34 -0400 (Thu, 21 Oct 2010) $
* </pre>
* @author $Author: ips_terabyte $
* @copyright © 2001 - 2009 Invision Power Services, Inc.
* @license http://www.invisionpower.com/community/board/license.html
* @package IP.Board
* @subpackage Portal
* @link http://www.invisionpower.com
* @since 1st April 2004
* @version $Revision: 7011 $
if ( ! defined( 'IN_IPB' ) )
print "<h1>Incorrect access</h1>You cannot access this file directly. If you have recently upgraded, make sure you upgraded all the relevant files.";
exit();
class public_portal_portal_portal extends ipsCommand
* Array of portal objects
* @access protected
* @var array Registered portal objects
protected $portal_object = array();
* Array of replacement tags
* @access protected
* @var array Replacement tags
protected $replace_tags = array();
* Array of tags to module...
* @access protected
* @var array Tags => Modules mapping
protected $remap_tags_module = array();
* Array of tags to function...
* @access protected
* @var array Tags => Function mapping
protected $remap_tags_function = array();
* Array of module objects
* @access protected
* @var array Module objects
protected $module_objects = array();
* Basic template, replaced as needed
* @access protected
* @var string Basic skin template to replace
protected $template = array();
* Main class entry point
* @access public
* @param object ipsRegistry reference
* @return void [Outputs to screen]
public function doExecute( ipsRegistry $registry )
// INIT
$conf_groups = array();
$found_tags = array();
$found_modules = array();
// Make sure the portal is installed an enabled
if( ! IPSLib::appIsInstalled( 'portal' ) )
$this->registry->output->showError( 'no_permission', 1076, null, null, 404 );
// Get settings...
foreach( $this->cache->getCache('portal') as $portal_data )
if( ! IPSLib::appIsInstalled( $portal_data['_app_dir'] ) )
continue;
if ( $portal_data['pc_settings_keyword'] )
$conf_groups[] = "'" . $portal_data['pc_settings_keyword'] . "'";
// Remap tags
if ( is_array( $portal_data['pc_exportable_tags'] ) AND count( $portal_data['pc_exportable_tags'] ) )
foreach( $portal_data['pc_exportable_tags'] as $tag => $tag_data )
$this->remap_tags_function[ $tag ] = $tag_data[0];
$this->remap_tags_module[ $tag ] = $portal_data['pc_key'];
// Now really get them...
$_where = (is_array($conf_groups) AND count($conf_groups)) ? 't.conf_title_keyword IN(' . implode( ",", $conf_groups ) . ") OR " : '';
$this->DB->build( array( 'select' => 'c.conf_key, c.conf_value, c.conf_default',
'from' => array( 'core_sys_conf_settings' => 'c' ),
'where' => $_where . "c.conf_key LIKE 'csite%'",
'add_join' => array(
array(
'select' => 't.conf_title_id, t.conf_title_keyword',
'from' => array( 'core_sys_settings_titles' => 't' ),
'where' => 'c.conf_group=t.conf_title_id',
'type' => "left"
$this->DB->execute();
// Set 'em up
while( $r = $this->DB->fetch() )
$this->settings[ $r['conf_key']] = $r['conf_value'] != "" ? $r['conf_value'] : $r['conf_default'] ;
// Get global skin and language files
ipsRegistry::getClass( 'class_localization')->loadLanguageFile( array( 'public_portal' ) );
// Assign skeletal template ma-doo-bob
$this->template = $this->registry->getClass('output')->getTemplate('portal')->skeletonTemplate();
// Grab all special tags
preg_match_all( "#<!--\:\ :(.+?)\:\:-->#", $this->template, $match );
// Assign functions
for ( $i=0, $m=count($match[0]); $i < $m; $i++ )
$tag = $match[1][$i];
if ( $this->remap_tags_module[ $tag ] )
$found_tags[ $tag ] = 1;
if ( $this->remap_tags_module[ $tag ])
$found_modules[ $this->remap_tags_module[ $tag ] ] = 1;
// Require modules...
if ( is_array( $found_modules ) AND count( $found_modules ) )
foreach( $found_modules as $mod_name => $pointless )
if ( ! is_object( $this->module_objects[ $mod_name ] ) )
if ( file_exists( $this->caches['portal'][ $mod_name ]['_file_location'] ) )
$constructor = IPSLib::loadLibrary( $this->caches['portal'][ $mod_name ]['_file_location'], 'ppi_' . $mod_name, $this->caches['portal'][ $mod_name ]['_app_dir'] );
$this->module_objects[ $mod_name ] = new $constructor();
$this->module_objects[ $mod_name ]->makeRegistryShortcuts( $this->registry );
$this->module_objects[ $mod_name ]->init();
// Get the tag replacements...
if ( is_array( $found_tags ) AND count( $found_tags ) )
foreach( $found_tags as $tag_name => $even_more_pointless )
$mod_obj = $this->remap_tags_module[ $tag_name ];
$fun_obj = $this->remap_tags_function[ $tag_name ];
if ( method_exists( $this->module_objects[ $mod_obj ], $fun_obj ) )
$this->replace_tags[ $tag_name ] = $this->module_objects[ $mod_obj ]->$fun_obj();
continue;
$this->_do_output();
* Internal do output method. Extend class and overwrite method if you need to modify this functionality.
* @access protected
* @return void
protected function _do_output()
// SITE REPLACEMENTS
foreach( $this->replace_tags as $sbk => $sbv )
$this->template = str_replace( "<!--::" . $sbk . "::-->", $sbv, $this->template );
// Pass to print...
$this->registry->output->addContent( $this->template );
$this->registry->output->setTitle( $this->settings['csite_title'] );
$this->registry->output->addNavigation( $this->settings['csite_title'], 'app=portal' );
$this->registry->output->sendOutput();
exit();
}[/long]
Edytowane przez DawPi
code -> long
Przebudowałeś cache? Dodałeś cokolwiek na portal?
