Fatal Error - Your settings could not be read by IP.Board
Witam po przenosinach forum mam taki error:
Your settings could not be read by IP.Board. This is a fatal error and IP.Board cannot function while this issue persists.
This issue is generally caused by changing your character set in the ACP to one that does not support data stored in the rest of your settings, or by restoring a database backup/completing a server transfer and importing your database tables using the wrong character set or collation. You should contact IPS Technical Support for further assistance.
Proszę o pomoc ponieważ nie mam pojęcia jak to naprawić.
Edytowane przez Zaxer
Gdzie to upgradeFinish mam wklejic?
//wklejilem to do nowego folderu w admin i gdy go uruchamiam mam:
You can try to refresh the page by clicking here
O tak wkleiłem:
admin/upgradeFinish/index.php
Nie miałem go wcześniej.
Error Log z folderu Admin:
[20-Nov-2012 10:13:44] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:14:19] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:17:38] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 631
Error log z głównego:
[28-Oct-2012 12:24:12] PHP Fatal error:  Class 'db_driver_' not found in /home/u612262036/public_html/admin/sources/base/ipsRegistry.php on line 2552
[28-Oct-2012 12:26:35] PHP Fatal error:  Class 'db_driver_' not found in /home/u612262036/public_html/admin/sources/base/ipsRegistry.php on line 2552
[08-Nov-2012 17:33:02] PHP Catchable fatal error:  Object of class ipsRegistry could not be converted to string in /home/u612262036/public_html/cache/skin_cache/cacheid_4/skin_stats.php on line 93
[09-Nov-2012 09:36:43] PHP Catchable fatal error:  Object of class ipsRegistry could not be converted to string in /home/u612262036/public_html/cache/skin_cache/cacheid_4/skin_stats.php on line 93
[09-Nov-2012 21:05:36] PHP Catchable fatal error:  Object of class ipsRegistry could not be converted to string in /home/u612262036/public_html/cache/skin_cache/cacheid_4/skin_stats.php on line 93
[09-Nov-2012 22:50:50] PHP Catchable fatal error:  Object of class ipsRegistry could not be converted to string in /home/u612262036/public_html/cache/skin_cache/cacheid_4/skin_stats.php on line 93
[10-Nov-2012 12:47:41] PHP Catchable fatal error:  Object of class ipsRegistry could not be converted to string in /home/u612262036/public_html/cache/skin_cache/cacheid_4/skin_stats.php on line 93
[10-Nov-2012 12:49:21] PHP Catchable fatal error:  Object of class ipsRegistry could not be converted to string in /home/u612262036/public_html/cache/skin_cache/cacheid_4/skin_stats.php on line 93
[10-Nov-2012 16:52:53] PHP Catchable fatal error:  Object of class ipsRegistry could not be converted to string in /home/u612262036/public_html/cache/skin_cache/cacheid_4/skin_stats.php on line 93
[12-Nov-2012 08:07:25] PHP Fatal error:  Call to a member function topicSig_view() on a non-object in /home/u612262036/public_html/admin/applications_addon/other/jawards/app_class_jawards.php on line 170
[12-Nov-2012 08:07:47] PHP Fatal error:  Call to a member function topicSig_view() on a non-object in /home/u612262036/public_html/admin/applications_addon/other/jawards/app_class_jawards.php on line 170
[12-Nov-2012 08:08:49] PHP Fatal error:  Call to a member function giveAward_form() on a non-object in /home/u612262036/public_html/admin/applications_addon/other/jawards/modules_public/awards/awards.php on line 109
[12-Nov-2012 08:09:00] PHP Fatal error:  Call to a member function category_row_start() on a non-object in /home/u612262036/public_html/admin/applications_addon/other/jawards/modules_public/awards/awards.php on line 186
[12-Nov-2012 12:51:24] PHP Catchable fatal error:  Object of class ipsRegistry could not be converted to string in /home/u612262036/public_html/cache/skin_cache/cacheid_4/skin_stats.php on line 93
[12-Nov-2012 12:51:27] PHP Catchable fatal error:  Object of class ipsRegistry could not be converted to string in /home/u612262036/public_html/cache/skin_cache/cacheid_4/skin_stats.php on line 93
[12-Nov-2012 12:51:29] PHP Catchable fatal error:  Object of class ipsRegistry could not be converted to string in /home/u612262036/public_html/cache/skin_cache/cacheid_4/skin_stats.php on line 93
[12-Nov-2012 16:23:22] PHP Catchable fatal error:  Object of class ipsRegistry could not be converted to string in /home/u612262036/public_html/cache/skin_cache/cacheid_4/skin_stats.php on line 93
[12-Nov-2012 16:23:29] PHP Catchable fatal error:  Object of class ipsRegistry could not be converted to string in /home/u612262036/public_html/cache/skin_cache/cacheid_4/skin_stats.php on line 93
[12-Nov-2012 22:32:09] PHP Catchable fatal error:  Object of class ipsRegistry could not be converted to string in /home/u612262036/public_html/cache/skin_cache/cacheid_4/skin_stats.php on line 93
[13-Nov-2012 13:44:22] PHP Catchable fatal error:  Object of class ipsRegistry could not be converted to string in /home/u612262036/public_html/cache/skin_cache/cacheid_4/skin_stats.php on line 93
[13-Nov-2012 17:34:38] PHP Catchable fatal error:  Object of class ipsRegistry could not be converted to string in /home/u612262036/public_html/cache/skin_cache/cacheid_4/skin_stats.php on line 93
[14-Nov-2012 21:07:08] PHP Catchable fatal error:  Object of class ipsRegistry could not be converted to string in /home/u612262036/public_html/cache/skin_cache/cacheid_4/skin_stats.php on line 93
[18-Nov-2012 12:55:45] PHP Warning:  mysqli_query() expects parameter 1 to be mysqli, null given in /home/u612262036/public_html/ips_kernel/classDbMysqliClient.php on line 234
[18-Nov-2012 12:55:45] PHP Warning:  mysqli_error() expects parameter 1 to be mysqli, null given in /home/u612262036/public_html/ips_kernel/classDbMysqliClient.php on line 617
[18-Nov-2012 12:55:45] PHP Warning:  mysqli_errno() expects parameter 1 to be mysqli, null given in /home/u612262036/public_html/ips_kernel/classDbMysqliClient.php on line 600
[19-Nov-2012 16:34:02] PHP Fatal error:  Call to a member function listings_row() on a non-object in /home/u612262036/public_html/admin/applications_addon/other/awards/modules_public/awards/awards.php on line 236
[19-Nov-2012 16:43:23] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:43:23] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:43:25] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:43:25] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:43:26] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:43:26] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:43:30] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:43:30] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:43:33] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:43:33] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:43:36] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:43:36] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:43:54] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:43:54] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:44:04] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:44:04] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:44:34] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:44:34] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:44:55] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:44:55] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:45:03] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:45:03] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:45:07] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:45:07] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:45:53] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:45:53] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:45:56] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:45:56] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:46:13] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:46:13] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:46:16] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:46:16] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:46:23] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:46:23] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:46:26] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:46:26] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:46:32] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:46:32] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:46:34] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:46:34] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:46:37] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:46:37] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:46:38] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:46:38] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:46:40] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:46:40] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_f20148d1d971260aa0b95851d51204ad.php on line 15
[19-Nov-2012 16:47:34] PHP Fatal error:  Call to a member function listings_row() on a non-object in /home/u612262036/public_html/admin/applications_addon/other/awards/modules_public/awards/awards.php on line 236
[19-Nov-2012 16:49:07] PHP Fatal error:  Call to a member function listings_row() on a non-object in /home/u612262036/public_html/admin/applications_addon/other/awards/modules_public/awards/awards.php on line 236
[19-Nov-2012 12:54:49] PHP Parse error:  syntax error, unexpected '=' in /home/u612262036/public_html/initdata.php on line 369
[19-Nov-2012 12:55:27] PHP Parse error:  syntax error, unexpected '=' in /home/u612262036/public_html/initdata.php on line 369
[19-Nov-2012 12:56:03] PHP Parse error:  syntax error, unexpected '=' in /home/u612262036/public_html/initdata.php on line 369
[19-Nov-2012 12:56:08] PHP Parse error:  syntax error, unexpected '=' in /home/u612262036/public_html/initdata.php on line 369
[19-Nov-2012 12:56:23] PHP Parse error:  syntax error, unexpected '=' in /home/u612262036/public_html/initdata.php on line 369
[19-Nov-2012 12:59:01] PHP Parse error:  syntax error, unexpected '=' in /home/u612262036/public_html/initdata.php on line 369
[19-Nov-2012 12:59:02] PHP Parse error:  syntax error, unexpected '=' in /home/u612262036/public_html/initdata.php on line 369
[19-Nov-2012 12:59:13] PHP Parse error:  syntax error, unexpected '=' in /home/u612262036/public_html/initdata.php on line 369
[19-Nov-2012 18:00:47] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_395db44527680f2ae4ac9225d50363d9.php on line 15
[19-Nov-2012 18:00:47] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_395db44527680f2ae4ac9225d50363d9.php on line 15
[19-Nov-2012 18:00:58] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_395db44527680f2ae4ac9225d50363d9.php on line 15
[19-Nov-2012 18:00:58] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_395db44527680f2ae4ac9225d50363d9.php on line 15
[19-Nov-2012 18:01:02] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_395db44527680f2ae4ac9225d50363d9.php on line 15
[19-Nov-2012 18:01:02] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_395db44527680f2ae4ac9225d50363d9.php on line 15
[19-Nov-2012 18:01:08] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_395db44527680f2ae4ac9225d50363d9.php on line 15
[19-Nov-2012 18:01:08] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_395db44527680f2ae4ac9225d50363d9.php on line 15
[19-Nov-2012 18:05:55] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_395db44527680f2ae4ac9225d50363d9.php on line 15
[19-Nov-2012 18:05:55] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_395db44527680f2ae4ac9225d50363d9.php on line 15
[19-Nov-2012 18:07:12] PHP Fatal error:  require() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/publicAwarding_e1d1cf286a647db2f3c44353a8223184.php on line 15
[19-Nov-2012 18:07:27] PHP Fatal error:  require() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/publicAwarding_e1d1cf286a647db2f3c44353a8223184.php on line 15
[19-Nov-2012 18:08:27] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_395db44527680f2ae4ac9225d50363d9.php on line 15
[19-Nov-2012 18:08:27] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_395db44527680f2ae4ac9225d50363d9.php on line 15
[19-Nov-2012 18:09:24] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_395db44527680f2ae4ac9225d50363d9.php on line 15
[19-Nov-2012 18:09:24] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_395db44527680f2ae4ac9225d50363d9.php on line 15
[19-Nov-2012 18:10:11] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_395db44527680f2ae4ac9225d50363d9.php on line 15
[19-Nov-2012 18:10:11] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_395db44527680f2ae4ac9225d50363d9.php on line 15
[19-Nov-2012 18:12:35] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_395db44527680f2ae4ac9225d50363d9.php on line 15
[19-Nov-2012 18:12:35] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_395db44527680f2ae4ac9225d50363d9.php on line 15
[19-Nov-2012 18:13:23] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_395db44527680f2ae4ac9225d50363d9.php on line 15
[19-Nov-2012 18:13:23] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_395db44527680f2ae4ac9225d50363d9.php on line 15
[20-Nov-2012 15:07:11] PHP Fatal error:  Uncaught exception 'Exception' with message 'class_awards is not an object' in /home/u612262036/public_html/admin/sources/base/ipsRegistry.php:1079
Stack trace:
#0 /home/u612262036/public_html/hooks/publicAwarding_e1d1cf286a647db2f3c44353a8223184.php(25): ipsRegistry::getClass('class_awards')
#1 /home/u612262036/public_html/admin/sources/classes/output/publicOutput.php(3462): publicAwarding->getOutput()
#2 /home/u612262036/public_html/admin/sources/classes/output/publicOutput.php(2724): output->templateHooks('<!DOCTYPE html>...')
#3 /home/u612262036/public_html/admin/applications/members/modules_public/profile/view.php(82): output->sendOutput()
#4 /home/u612262036/public_html/admin/sources/base/ipsController.php(306): public_members_profile_view->doExecute(Object(ipsRegistry))
#5 /home/u612262036/public_html/admin/sources/base/ipsController.php(120): ipsCommand->execute(Object(ipsRegistry))
#6 /home/u612262036/public_html/admin/sources/base/ipsController.php(65): ipsController->handleRequest()
#7 /home/u61226 in /home/u612262036/public_html/admin/sources/base/ipsRegistry.php on line 1079
[20-Nov-2012 15:07:19] PHP Fatal error:  Uncaught exception 'Exception' with message 'class_awards is not an object' in /home/u612262036/public_html/admin/sources/base/ipsRegistry.php:1079
Stack trace:
[20-Nov-2012 15:07:31] PHP Fatal error:  Uncaught exception 'Exception' with message 'class_awards is not an object' in /home/u612262036/public_html/admin/sources/base/ipsRegistry.php:1079
Stack trace:
[20-Nov-2012 15:07:45] PHP Fatal error:  Uncaught exception 'Exception' with message 'class_awards is not an object' in /home/u612262036/public_html/admin/sources/base/ipsRegistry.php:1079
Stack trace:
[20-Nov-2012 15:07:57] PHP Fatal error:  Uncaught exception 'Exception' with message 'class_awards is not an object' in /home/u612262036/public_html/admin/sources/base/ipsRegistry.php:1079
Stack trace:
[20-Nov-2012 15:08:28] PHP Fatal error:  Uncaught exception 'Exception' with message 'class_awards is not an object' in /home/u612262036/public_html/admin/sources/base/ipsRegistry.php:1079
Stack trace:
[20-Nov-2012 15:10:29] PHP Catchable fatal error:  Object of class ipsRegistry could not be converted to string in /home/u612262036/public_html/cache/skin_cache/cacheid_4/skin_stats.php on line 93
[20-Nov-2012 15:12:46] PHP Fatal error:  Call to a member function topicPost_view() on a non-object in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 83
[20-Nov-2012 15:12:49] PHP Fatal error:  Call to a member function topicPost_view() on a non-object in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 83
[20-Nov-2012 10:13:38] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:13:39] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:13:45] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:13:48] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:13:49] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:13:54] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:14:22] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:14:35] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:14:37] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:14:39] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:14:40] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:14:42] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:15:02] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:15:06] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:15:08] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:15:13] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:15:19] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:15:20] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:15:23] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:15:38] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:15:39] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:15:40] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:15:42] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:16:10] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:16:28] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:16:31] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 633
[20-Nov-2012 10:16:38] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 632
[20-Nov-2012 10:17:03] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 632
[20-Nov-2012 10:17:21] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 632
[20-Nov-2012 10:17:34] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 631
[20-Nov-2012 10:18:18] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 631
[20-Nov-2012 10:18:25] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 631
[20-Nov-2012 10:18:36] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 631
[20-Nov-2012 10:19:04] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 631
[20-Nov-2012 10:19:26] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 631
[20-Nov-2012 10:19:47] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 631
[20-Nov-2012 10:19:51] PHP Parse error:  syntax error, unexpected ';', expecting ']' in /home/u612262036/public_html/initdata.php on line 631
[20-Nov-2012 10:20:16] PHP Warning:  require_once(./initdata.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/index.php on line 21
[20-Nov-2012 10:20:16] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required './initdata.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/u612262036/public_html/index.php on line 21
[20-Nov-2012 10:20:20] PHP Warning:  require_once(./initdata.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/index.php on line 21
[20-Nov-2012 10:20:20] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required './initdata.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/u612262036/public_html/index.php on line 21
[20-Nov-2012 15:21:10] PHP Fatal error:  Uncaught exception 'Exception' with message 'classAwards is not an object' in /home/u612262036/public_html/admin/sources/base/ipsRegistry.php:1079
Stack trace:
#0 /home/u612262036/public_html/admin/applications_addon/other/awards/modules_public/view/view.php(71): ipsRegistry::getClass('classAwards')
#1 /home/u612262036/public_html/admin/applications_addon/other/awards/modules_public/view/view.php(56): public_awards_view_view->awardsList()
#2 /home/u612262036/public_html/admin/sources/base/ipsController.php(306): public_awards_view_view->doExecute(Object(ipsRegistry))
#3 /home/u612262036/public_html/admin/sources/base/ipsController.php(120): ipsCommand->execute(Object(ipsRegistry))
#4 /home/u612262036/public_html/admin/sources/base/ipsController.php(65): ipsController->handleRequest()
#5 /home/u612262036/public_html/index.php(26): ipsController::run()
#6 {main}
  thrown in /home/u612262036/public_html/admin/sources/base/ipsRegistry.php on line 1079
[20-Nov-2012 15:26:30] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:26:30] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:26:31] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:26:31] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:26:32] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:26:32] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:28:32] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:28:32] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:28:35] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:28:35] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:29:30] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:29:30] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:29:34] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:29:34] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:29:38] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:29:38] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:29:49] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:29:49] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:29:53] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:29:53] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:33:55] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:33:55] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:34:20] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:34:20] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:34:24] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:34:24] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:34:29] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:34:29] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:34:34] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:34:34] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:34:57] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:34:57] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:35:01] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:35:01] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:35:05] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:35:05] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:35:08] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:35:08] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:35:27] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:35:27] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:35:45] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:35:45] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:35:48] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:35:48] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:35:51] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:35:51] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:35:52] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:35:52] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:35:58] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:35:58] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:36:35] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:36:35] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:36:39] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:36:39] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:36:47] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:36:47] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:36:58] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:36:58] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:37:30] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:37:30] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:37:48] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:37:48] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:37:52] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:37:52] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:38:01] PHP Fatal error:  require() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/publicAwarding_37bd2f332184d05a677c2edc78dd0c4d.php on line 15
[20-Nov-2012 15:38:32] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:38:32] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:39:07] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:39:07] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:40:51] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:40:51] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:41:13] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:41:13] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:41:19] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:41:19] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:41:23] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:41:23] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:41:28] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:41:28] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:45:15] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:45:15] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:47:02] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:47:02] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:49:34] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:49:34] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:49:41] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:49:41] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:49:52] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:49:52] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:49:59] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:49:59] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:50:53] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:50:53] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:51:13] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:51:13] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:52:01] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:52:01] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:52:04] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:52:04] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:52:24] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:52:24] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:52:45] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:52:45] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:54:05] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:54:05] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:55:01] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:55:01] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:56:31] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:56:31] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:56:34] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:56:34] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:56:41] PHP Fatal error:  require() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/publicAwarding_37bd2f332184d05a677c2edc78dd0c4d.php on line 15
[20-Nov-2012 15:56:50] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:56:50] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:56:56] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:56:56] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:57:54] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:57:54] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:58:02] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:58:02] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 15:59:36] PHP Fatal error:  require() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/publicAwarding_37bd2f332184d05a677c2edc78dd0c4d.php on line 15
[20-Nov-2012 15:59:44] PHP Fatal error:  require() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/publicAwarding_37bd2f332184d05a677c2edc78dd0c4d.php on line 15
[20-Nov-2012 16:00:02] PHP Warning:  require_once(/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[20-Nov-2012 16:00:02] PHP Fatal error:  require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/u612262036/public_html/admin/applications_addon/other/awards/app_class_awards.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/u612262036/public_html/ips_kernel/') in /home/u612262036/public_html/hooks/awardsPostView_240553cf9cfce3a3c4931f25727741f0.php on line 15
[28-Nov-2012 21:43:53] PHP Warning:  mysqli_query() [<a href='function.mysqli-query'>function.mysqli-query</a>]: (HY000/2013): Lost connection to MySQL server during query in /home/u612262036/public_html/ips_kernel/classDbMysqliClient.php on line 234
[16-Dec-2012 18:07:56] PHP Fatal error:  Call to a member function showForm() on a non-object in /home/u612262036/public_html/admin/applications_addon/other/ihost/modules_public/global/images.php on line 155
Edytowane przez Zaxer
Ale czysty plik czy z mojego starego ftp?
/Wkleiłem czysty i nadal to samo.
Otwórz plik: initdata.php
define( 'IN_IPB', 1 );
Znajdź:
Dodaj poniżej:
define( 'SKIP_UPGRADE_CHECK', 1 );
Zapisz i wyślij. Już nie powinno o tym informować.
Choć ja bym wolał wykonać poprawnie aktualizację.
Lecz to jest strasznie stary błąd
Mój plik się konczy na
I jest to linia
511. Więc lini 631 na pewno nie mam.
Wlasnie nie nadal nas tronie glownej jest blad Fatal ERROR a na stronie
admin/upgradeFinish/
Błąd:
Date: Mon, 11 Feb 2013 14:56:30 +0000
Error: 1146 - Table 'Moja nazwa bazy_ipb.ipb_members' doesn't exist
IP Address: MOJE IP - /admin/upgradeFinish/
mySQL query error: SELECT * FROM ipb_members WHERE member_group_id=4 ORDER BY last_visit DESC LIMIT 0,1
Teraz udało mi się odpalić już ten upgrade ale wyskakuje:
Fatal error: Uncaught exception 'Exception' with message 'output is not an object' in /home/u983847216/public_html/admin/sources/base/ipsRegistry.php:1079 Stack trace: #0 /home/u983847216/public_html/admin/sources/base/ipsRegistry.php(1177): ipsRegistry::getClass('output') #1 /home/u983847216/public_html/admin/applications/core/modules_admin/applications/applications.php(2746): ipsRegistry->__get('output') #2 /home/u983847216/public_html/admin/sources/base/ipsRegistry.php(3379): admin_core_applications_applications->applicationsRecache() #3 /home/u983847216/public_html/admin/sources/base/ipsRegistry.php(2164): ips_CacheRegistry::rebuildCache('app_cache', 'global') #4 /home/u983847216/public_html/admin/sources/base/ipsRegistry.php(591): ipsRegistry->checkCaches() #5 /home/u983847216/public_html/admin/sources/base/ipsController.php(77): ipsRegistry::init() #6 /home/u983847216/public_html/admin/sources/base/ipsController.php(64): ipsController->init() #7 /home/u983847216/public_html/admin/index.php(39): ipsController::run() in/home/u983847216/public_html/admin/sources/base/ipsRegistry.php on line 1079
Przy 10 kroku.
No nie było tabeli po prostu :)
baza źle się wyexportowała.
